I’ve added 8 Fibaro Roller Shutter devices without any issue.
But when trying to add another one: inclusion is ok and I have access to all the needed configuration parameters but Home Assistant did not create the cover entity like it did for the others.
I’ve tried with a Qubino Flush shutter and getting exactly the same issue.
Also tried to remove/add the node but no change: still missing the related cover entity…
Note that HA was able to create the others entities like:
sensor.fibaro_walli_roller_shutter_electric_consumed_w
sensor.fibaro_walli_roller_shutter_electric_consumed_kwh
binary_sensor.fibaro_walli_roller_shutter_power_management_over_current_detected
Does anyone know how to fix that?
Thanks & regards
