Hi, i’m upgrading home with ZWave thermostats and is some areas where i don’t need thermostat wall mounted, i will use Qubino Flush On/Off thermostat (ZMNHID1). Got one to try out. Connected and it appeared under Climate in HA.
problem i’m getting is that Target temperature stays 23, no matter that i change on interface:
HI, did this get resolved? I am in the process of getting my installed and even considered getting two to separate my radiant heating control and to keep each under 10Amps. Initially I simply wanted to use the 24V controller, but neither Qubino support nor the floor heating manufacturer could agree on an approach to do so. So now I am connecting it to the 110V and making to do the controlling.
No update from my side apart the fact that I won’t use the flush thermostat and go for a flush 1d to control the 24v ac valves of my under floor heating water based system. The flush termostat does not work well with open zwave but you can build a thermostat using this https://www.home-assistant.io/components/climate.generic_thermostat/
All you need is a switch and a temperature sensor and the qubino flush 1d has both.
I will update when things are installed but it will take a couple of weeks.
Hope this helps.
