Qubino Flush RGBW Dimmer and Zooz Zen31 not working with HA
I have a Qubino ZMNHWD dimmer and an Zooz Zen31 dimmer. I can’t either of these devices to work with HA. I’ve gone through several cycles of exclude/include, factory reset, but neither of these dimmers will power up the LED strip. The Zooz, I used previously with OpenHAB and it worked just fine ( and still does if I include it in that system). Both dimmers have various entities, switches and color color controls, but none of them power up the strip. Yes, there is power going to the strip, but I’m at a loss. Can someone help me out here?
At the bottom of the master control for the RGBW there are 2 sliders: 1 - to control the RGB intensity and the other controls the White channel. Make sure one of them is moved to the right at least a little. The brightness slider on the top will not really turn any of the LEDs on unless one or both of the bottom sliders have been moved to the right ( <0 ). I ran across the same thing.
