I’m having some troubles with the Qubino Flush Shutter zwave device, I configure it as a Shutter (not ventian mode) my curtains have limit switches so when it reach a limit the motor automaticlly stops, so i configure as follow:
Parameter no. 71 – Operating modes: Shutter
Parameter no. 74 – Motor moving up/down time: 75
Parameter no. 76 - Motor operation detection: 0
Parameter no. 85 – Power consumption max delay time: 0
The device is able to “calibrate” up and down correctly, aftwer that the UI of HA says it is 100% open, y cant controll it from the UI componentes, they are not working… but i can use the Service panel to call the services, here i can open and close (full 0 or 100%) but set_position is not working, i call the service, OZW log shows the messages but nothing happens.
The only thing i dont like in the logs is that it does not matter if you open, close or set position, the device answer is allways Level=254 for old and new value…
2018-08-11 13:32:51.921 Info, Node060, Received a MultiChannelEncap from node 60, endpoint 1 for Command Class COMMAND_CLASS_SWITCH_MULTILEVEL
2018-08-11 13:32:51.921 Info, Node060, Received SwitchMultiLevel report: level=254
Looking at the OZW logs looks like the device allways says it is at 100% but i’m not an expert in zwave/openzwave, may be someone can give mi a hand on that.
Note that i’m using the level entity not the switch one (that is not working either)
Following the relevant openzwave log info for the three diferent acctions:
Open cover:
2018-08-11 12:45:16.784 Info, Node060, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Up - 1 - 1 - true
2018-08-11 12:45:16.784 Info, Node060, SwitchMultilevel::StartLevelChange - Starting a level change
2018-08-11 12:45:16.784 Info, Node060, Direction: Up
2018-08-11 12:45:16.784 Info, Node060, Ignore Start Level: True
2018-08-11 12:45:16.785 Info, Node060, Start Level: 0
2018-08-11 12:45:16.785 Detail, Node060, Queuing (Send) MultiChannel Encapsulated (instance=1): SwitchMultilevelCmd_StartLevelChange (Node=60): 0x01, 0x0f, 0x00, 0x13, 0x3c, 0x08, 0x60, 0x0d, 0x01, 0x01, 0x26, 0x04, 0x20, 0x00, 0x25, 0xea, 0x77
2018-08-11 12:45:16.786 Info, Node060, Sending (Send) message (Callback ID=0xea, Expected Reply=0x13) - MultiChannel Encapsulated (instance=1): SwitchMultilevelCmd_StartLevelChange (Node=60): 0x01, 0x0f, 0x00, 0x13, 0x3c, 0x08, 0x60, 0x0d, 0x01, 0x01, 0x26, 0x04, 0x20, 0x00, 0x25, 0xea, 0x77
2018-08-11 12:45:16.794 Detail, Node060, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-08-11 12:45:16.794 Detail, Node060, ZW_SEND_DATA delivered to Z-Wave stack
2018-08-11 12:45:16.811 Detail, Node060, Received: 0x01, 0x07, 0x00, 0x13, 0xea, 0x00, 0x00, 0x02, 0x03
2018-08-11 12:45:16.812 Detail, Node060, ZW_SEND_DATA Request with callback ID 0xea received (expected 0xea)
2018-08-11 12:45:16.812 Info, Node060, Request RTT 25 Average Request RTT 34
2018-08-11 12:45:16.812 Detail, Node060, Removing current message
2018-08-11 12:45:18.017 Detail, Node060, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x3c, 0x0a, 0x32, 0x02, 0x21, 0x34, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0xf7
2018-08-11 12:45:18.017 Detail, Node060, Refreshed Value: old value=false, new value=false, type=bool
2018-08-11 12:45:18.018 Detail, Node060, Changes to this value are not verified
2018-08-11 12:45:18.018 Info, Node060, Received Meter report from node 60: Power=1.5W
2018-08-11 12:45:18.018 Detail, Node060, Refreshed Value: old value=0.0, new value=1.5, type=decimal
2018-08-11 12:45:18.018 Detail, Node060, Notification: ValueChanged
2018-08-11 12:45:18.049 Detail, Node060, Notification: ValueChanged
2018-08-11 12:45:25.541 Detail, Node060, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x3c, 0x03, 0x26, 0x03, 0xfe, 0x16
2018-08-11 12:45:25.542 Info, Node060, Received SwitchMultiLevel report: level=254
2018-08-11 12:45:25.542 Detail, Node060, Refreshed Value: old value=254, new value=254, type=byte
2018-08-11 12:45:25.542 Detail, Node060, Changes to this value are not verified
2018-08-11 12:45:25.542 Detail, Node060, Notification: ValueChanged
2018-08-11 12:45:26.564 Detail, Node060, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x3c, 0x0a, 0x32, 0x02, 0x21, 0x34, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xf8
2018-08-11 12:45:26.565 Detail, Node060, Refreshed Value: old value=false, new value=false, type=bool
2018-08-11 12:45:26.565 Detail, Node060, Changes to this value are not verified
2018-08-11 12:45:26.565 Info, Node060, Received Meter report from node 60: Power=0.0W
2018-08-11 12:45:26.566 Detail, Node060, Refreshed Value: old value=1.5, new value=0.0, type=decimal
2018-08-11 12:45:26.566 Detail, Node060, Changes to this value are not verified
2018-08-11 12:45:26.566 Detail, Node060, Notification: ValueChanged
2018-08-11 12:45:26.596 Detail, Node060, Notification: ValueChanged
Close cover:
2018-08-11 12:47:30.463 Info, Node060, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Down - 2 - 1 - true
2018-08-11 12:47:30.464 Info, Node060, SwitchMultilevel::StartLevelChange - Starting a level change
2018-08-11 12:47:30.464 Info, Node060, Direction: Down
2018-08-11 12:47:30.464 Info, Node060, Ignore Start Level: True
2018-08-11 12:47:30.465 Info, Node060, Start Level: 0
2018-08-11 12:47:30.465 Detail, Node060, Queuing (Send) MultiChannel Encapsulated (instance=1): SwitchMultilevelCmd_StartLevelChange (Node=60): 0x01, 0x0f, 0x00, 0x13, 0x3c, 0x08, 0x60, 0x0d, 0x01, 0x01, 0x26, 0x04, 0x60, 0x00, 0x25, 0xf8, 0x25
2018-08-11 12:47:30.466 Info, Node060, Sending (Send) message (Callback ID=0xf8, Expected Reply=0x13) - MultiChannel Encapsulated (instance=1): SwitchMultilevelCmd_StartLevelChange (Node=60): 0x01, 0x0f, 0x00, 0x13, 0x3c, 0x08, 0x60, 0x0d, 0x01, 0x01, 0x26, 0x04, 0x60, 0x00, 0x25, 0xf8, 0x25
2018-08-11 12:47:30.474 Detail, Node060, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-08-11 12:47:30.474 Detail, Node060, ZW_SEND_DATA delivered to Z-Wave stack
2018-08-11 12:47:30.491 Detail, Node060, Received: 0x01, 0x07, 0x00, 0x13, 0xf8, 0x00, 0x00, 0x02, 0x11
2018-08-11 12:47:30.491 Detail, Node060, ZW_SEND_DATA Request with callback ID 0xf8 received (expected 0xf8)
2018-08-11 12:47:30.491 Info, Node060, Request RTT 25 Average Request RTT 29
2018-08-11 12:47:30.492 Detail, Node060, Removing current message
2018-08-11 12:47:31.762 Detail, Node060, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x3c, 0x0a, 0x32, 0x02, 0x21, 0x34, 0x00, 0x00, 0x00, 0x13, 0x00, 0x00, 0xeb
2018-08-11 12:47:31.763 Detail, Node060, Refreshed Value: old value=false, new value=false, type=bool
2018-08-11 12:47:31.776 Detail, Node060, Changes to this value are not verified
2018-08-11 12:47:31.776 Info, Node060, Received Meter report from node 60: Power=1.9W
2018-08-11 12:47:31.777 Detail, Node060, Refreshed Value: old value=0.0, new value=1.9, type=decimal
2018-08-11 12:47:31.777 Detail, Node060, Changes to this value are not verified
2018-08-11 12:47:31.778 Detail, Node060, Notification: ValueChanged
2018-08-11 12:47:31.823 Detail, Node060, Notification: ValueChanged
2018-08-11 12:47:39.193 Detail, Node060, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x3c, 0x03, 0x26, 0x03, 0xfe, 0x16
2018-08-11 12:47:39.194 Info, Node060, Received SwitchMultiLevel report: level=254
2018-08-11 12:47:39.194 Detail, Node060, Refreshed Value: old value=254, new value=254, type=byte
2018-08-11 12:47:39.194 Detail, Node060, Changes to this value are not verified
2018-08-11 12:47:39.194 Detail, Node060, Notification: ValueChanged
2018-08-11 12:47:40.216 Detail, Node060, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x3c, 0x0a, 0x32, 0x02, 0x21, 0x34, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xf8
2018-08-11 12:47:40.216 Detail, Node060, Refreshed Value: old value=false, new value=false, type=bool
2018-08-11 12:47:40.216 Detail, Node060, Changes to this value are not verified
2018-08-11 12:47:40.216 Info, Node060, Received Meter report from node 60: Power=0.0W
2018-08-11 12:47:40.217 Detail, Node060, Refreshed Value: old value=1.9, new value=0.0, type=decimal
2018-08-11 12:47:40.217 Detail, Node060, Changes to this value are not verified
2018-08-11 12:47:40.217 Detail, Node060, Notification: ValueChanged
2018-08-11 12:47:40.247 Detail, Node060, Notification: ValueChanged
Set position:
2018-08-11 12:48:05.366 Info, Node060, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 1 - 50
2018-08-11 12:48:05.367 Info, Node060, SwitchMultilevel::Set - Setting to level 50
2018-08-11 12:48:05.367 Detail, Node060, Queuing (Send) MultiChannel Encapsulated (instance=1): SwitchMultilevelCmd_Set (Node=60): 0x01, 0x0e, 0x00, 0x13, 0x3c, 0x07, 0x60, 0x0d, 0x01, 0x01, 0x26, 0x01, 0x32, 0x25, 0xf9, 0x7d
2018-08-11 12:48:05.367 Detail, Node060, Queuing (Send) MultiChannel Encapsulated (instance=1): SwitchMultilevelCmd_Get (Node=60): 0x01, 0x0d, 0x00, 0x13, 0x3c, 0x06, 0x60, 0x0d, 0x01, 0x01, 0x26, 0x02, 0x25, 0xfa, 0x4d
2018-08-11 12:48:05.368 Info, Node060, Sending (Send) message (Callback ID=0xf9, Expected Reply=0x13) - MultiChannel Encapsulated (instance=1): SwitchMultilevelCmd_Set (Node=60): 0x01, 0x0e, 0x00, 0x13, 0x3c, 0x07, 0x60, 0x0d, 0x01, 0x01, 0x26, 0x01, 0x32, 0x25, 0xf9, 0x7d
2018-08-11 12:48:05.376 Detail, Node060, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-08-11 12:48:05.376 Detail, Node060, ZW_SEND_DATA delivered to Z-Wave stack
2018-08-11 12:48:05.393 Detail, Node060, Received: 0x01, 0x07, 0x00, 0x13, 0xf9, 0x00, 0x00, 0x03, 0x11
2018-08-11 12:48:05.393 Detail, Node060, ZW_SEND_DATA Request with callback ID 0xf9 received (expected 0xf9)
2018-08-11 12:48:05.393 Info, Node060, Request RTT 25 Average Request RTT 27
2018-08-11 12:48:05.394 Detail, Node060, Removing current message
2018-08-11 12:48:05.394 Info, Node060, Sending (Send) message (Callback ID=0xfa, Expected Reply=0x04) - MultiChannel Encapsulated (instance=1): SwitchMultilevelCmd_Get (Node=60): 0x01, 0x0d, 0x00, 0x13, 0x3c, 0x06, 0x60, 0x0d, 0x01, 0x01, 0x26, 0x02, 0x25, 0xfa, 0x4d
2018-08-11 12:48:05.402 Detail, Node060, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-08-11 12:48:05.402 Detail, Node060, ZW_SEND_DATA delivered to Z-Wave stack
2018-08-11 12:48:05.471 Detail, Node060, Received: 0x01, 0x07, 0x00, 0x13, 0xfa, 0x00, 0x00, 0x07, 0x16
2018-08-11 12:48:05.471 Detail, Node060, ZW_SEND_DATA Request with callback ID 0xfa received (expected 0xfa)
2018-08-11 12:48:05.471 Info, Node060, Request RTT 77 Average Request RTT 52
2018-08-11 12:48:05.521 Detail, Node060, Received: 0x01, 0x0d, 0x00, 0x04, 0x00, 0x3c, 0x07, 0x60, 0x0d, 0x01, 0x01, 0x26, 0x03, 0xfe, 0x7b
2018-08-11 12:48:05.521 Info, Node060, Response RTT 127 Average Response RTT 107
2018-08-11 12:48:05.522 Info, Node060, Received a MultiChannelEncap from node 60, endpoint 1 for Command Class COMMAND_CLASS_SWITCH_MULTILEVEL
2018-08-11 12:48:05.522 Info, Node060, Received SwitchMultiLevel report: level=254
2018-08-11 12:48:05.522 Detail, Node060, Refreshed Value: old value=254, new value=254, type=byte
2018-08-11 12:48:05.522 Detail, Node060, Changes to this value are not verified
2018-08-11 12:48:05.522 Detail, Node060, Expected reply and command class was received
2018-08-11 12:48:05.522 Detail, Node060, Message transaction complete
2018-08-11 12:48:05.522 Detail, Node060, Removing current message
2018-08-11 12:48:05.523 Detail, Node060, Notification: ValueChanged
2018-08-11 12:48:21.043 Detail, Node060, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x3c, 0x0a, 0x32, 0x02, 0x21, 0x34, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xf8
2018-08-11 12:48:21.044 Detail, Node060, Refreshed Value: old value=false, new value=false, type=bool
2018-08-11 12:48:21.044 Detail, Node060, Changes to this value are not verified
2018-08-11 12:48:21.044 Info, Node060, Received Meter report from node 60: Power=0.0W
2018-08-11 12:48:21.045 Detail, Node060, Refreshed Value: old value=0.0, new value=0.0, type=decimal
2018-08-11 12:48:21.045 Detail, Node060, Changes to this value are not verified
2018-08-11 12:48:21.045 Detail, Node060, Notification: ValueChanged
2018-08-11 12:48:21.076 Detail, Node060, Notification: ValueChanged
