I’m part way through configuring my new setup. I’ve added a good number of Fibaro Dimmer 2s and a couple of Qubino Relays with no issues. I’m following the same process for each device:
- Add Secure Node
- Watch until I get a completed message on the new node
- Click Save
- Stop HA from server control
- Modify zwcfg_ file and rename to suit
- Remove the entity file
- Restart HA
I do this on every add and it’s been working fine. I have 6 new Qubino Relays to add and not a single one will appear. Oddly I have seen a couple of numbers skipped in the zwcfg_ file, so it’s almost like they started to add, but didn’t get as far as the config.
Is there anywhere I can look to figure out why these aren’t adding?
I’m running 0.114.4 as a docker container on a physical Odroid box with a Z-Wave.me USB dongle
