Qubino ZMNHDD1: Manual operation status
I use Qubino dimmer (Qubino ZMNHDD1) in combination with a Z-Wave USB stick (Z-Wave.Me ZME_UZB1 USB) on a Raspberry, on it runs HASS.IO.
I mounted two of the dimmers under the light switches.
The following problem: If I press the light switch, the (new, updated) status is not displayed in home-assistant. So if I press the light switch manually to turn on the light, Home-Assistant will still display the light as “off”.
I can operate the dimmers via the home assistant interface, so in principle they work. The only thing that doesn’t work is the feedback signal for manual operation.
Does anyone have any idea how to correct this behavior?
The dimmers are configured as follows:
  • 1: Input 1 switch type: mono-stable (push button)
  • 20: Enable/Disable 3-way switch/additional switch: single push button (connected to I1)
  • 40: Power reporting in Watts on power change: 5 %
  • 42: Power reporting in Watts by time interval: 300 seconds
Thank you and many greetings
Vuk
Hi Vuk,
Did you resolve this? I am encountering the same challenge and was wondering how you resolved this.
Kr,
Dwaine
I have the same issue.
Best,
Antoine
I filed this issue yesterday, which I’m think is related to this problem: https://github.com/OpenZWave/open-zwave/issues/2400
