This just showed up and I’ve read it several times…what do I need to do here?
I’m a bit confused…
Thank you!!!
I’m a bit confused…
Thank you!!!
You need to go to your configuration.yaml
file (or wherever you configured the Variables integration if you use a split config) and delete the section for that integration. Once deleted you need to restart HA for the change to take effect.
