Hi everyone,
I’ve integrated several Xiaomi MiFlora sensors via ESPHome and am sending the data via MQTT to my server. The configuration works fine so far, but I want to make sure the sensor values are only posted every 5 minutes and not immediately as soon as they’re available. Below is my current configuration:
- platform: xiaomi_hhccjcy01
mac_address: "5C:85:7E:12:ED:CA"
temperature:
name: "MiFlora1 Temperature"
moisture:
name: "MiFlora1 Moisture"
illuminance:
name: "MiFlora1 Illuminance"
conductivity:
name: "MiFlora1 Soil Conductivity"
battery_level:
name: "MiFlora1 Battery Level"
update_interval: 5min # Update interval set here
mac_address: "5C:85:7E:12:ED:AB"
temperature:
name: "MiFlora2 Temperature"
moisture:
name: "MiFlora2 Moisture"
illuminance:
name: "MiFlora2 Illuminance"
conductivity:
name: "MiFlora2 Soil Conductivity"
battery_level:
name: "MiFlora2 Battery Level"
interval:
- interval: 5min
then:
- mqtt.publish:
topic: "florasensordevice/sensor1/temperature"
payload: !lambda |-
return to_string(id(miflora1_temperature).state);
- mqtt.publish:
topic: "florasensordevice/sensor1/moisture"
payload: !lambda |-
return to_string(id(miflora1_moisture).state);
My Goal:
I want to prevent the sensor values from being sent immediately after startup or when changes happen, and instead, have them only sent every 5 minutes.
Thanks in advance for any advice!
