Question about Fibaro FGK-10X (Door sensor)
In Home Assistant how do I get it to say open/closed. I only got a number 22/23.
What does this mean:
 - sensor.fibaro_system_fgk10x_door_opening_sensor_access_control
 - sensor.fibaro_system_fgk10x_door_opening_sensor_burglar
 - sensor.fibaro_system_fgk10x_door_opening_sensor_general
 - sensor.fibaro_system_fgk10x_door_opening_sensor_sourcenodeid
 - sensor.fibaro_system_fgk10x_door_opening_sensor_alarm_type
 - sensor.fibaro_system_fgk10x_door_opening_sensor_alarm_level
The access_control is the number 22/23
Sorry for dumb questions…
Edit: Now it showed up as binary_sensor.fibaro_system_fgk10x_door_opening_sensor_sensor
I maybe was to quick.
I’m having the same issue. I’m thinking I need to create another sensor and map the 22/23 values to on/off or open/close.
This is what I’ve come up with:
binary_sensor:
    sensors:
      front_door_open:
        friendly_name: Front Door Open
        entity_id: sensor.fibaro_door_fibaro_door_open
        device_class: opening
        value_template: >
          {{ states('sensor.fibaro_door_fibaro_door_open')|float == 22 }}
It seems to report open/close properly (so far).
I didn’t need to do anything. After a while it showed up as binary_sensor.
Interesting. I’ve had mine for less than a day, so I guess I’ll wait and see.
How it’s going?
Still working, but the sensors didn’t change. Oddly the one that should have been the open/close sensor didn’t report back so I went off of the state 22/23 to determine open/close with my template sensor. I installed another (different brand) door sensor and its binary sensor worked fine (though I had to customize its type to opening).
