Hey, Im pretty new to using home assistant and got a question about the “update to new version” inside HA.
Im running Home Assistant on a RPi 4 and everything works smoothly as it should.
A week or two back there was a notification that a new version of HA was available so I decided to upgrade it. It ended up with pretty much everything broke. I also use google drive backup addon but I couldnt even restore a backup in the new version of HA as I constantly was stuck in “HA is starting up”.
Only thing I could do with the little knowledge I got was to start from scratch and reinstall everyhing, including the raspberry.
Here we are again with a new update available but I’m a bit hesitant to update, if it aint broken leave it alone, right?
Any suggestion on how to avoid this from happening again if I want to update the version of HA?
Thanks!
