Question about "Product name collision" in z-wave log
I’m having good results with Hass.io 70.1, with 6 door sensors, 4 switches, 4 multi-sensors, a thermostat and a few web-based sensors. Loving it. But I’m struggling a bit with my garage door opener, but I’m hoping that I’m getting close. The opener communicates fine and I can see the statuses, but no switches are exposed. I believe I see something interesting in the log, but I couldn’t find details when I searched for a solution.
Config: Hass.io 0.70.1
Device: Linear GD00Z-4 Garage Door Opener Remote Controller
Node ID: 6
When I refresh this node and check the z-wave log, I notice that I am getting “Product name collision” messages with the opener’s switch. Log details:
2018-06-09 09:05:53.361 Info, Node006, Response RTT 37 Average Response RTT 37
2018-06-09 09:05:53.459 Info, Product name collision: VRS15-1LZ Switch type 301 id 209 manufacturerid 1d, collides with VRS15-1LZ Binary Scene Switch, type 301 id 209 manufacturerid 1d
2018-06-09 09:05:53.459 Info, Product name collision: VRF01-1LZ Multilevel Scene Switch - 1.5A Fan type 1001 id 209 manufacturerid 1d, collides with VRF01-1LZ Quiet Fan Speed Control, type 1001 id 209 manufacturerid 1d
2018-06-09 09:05:53.477 Info, Node006, Received manufacturer specific report from node 6: Manufacturer=Linear, Product=GD00Z-4 Garage Door Opener Remote Controller
I didn’t find any information on whether a “Product name collision” was fatal or just a warning.
Otherwise, I suspect that the device is communicating fine, since I can see the attributes of node 6:
node_id: 6
node_name: Linear GD00Z-4 Garage Door Opener Remote Controller
manufacturer_name: Linear
product_name: GD00Z-4 Garage Door Opener Remote Controller
query_stage: Complete
is_awake: true
is_ready: true
is_failed: false
is_info_received: true
max_baud_rate: 40000
is_zwave_plus: false
capabilities: listening,routing,beaming
neighbors: 1,2,3,4,5,8,9,12,13,14,15,17
sentCnt: 7
sentFailed: 0
retries: 0
receivedCnt: 1
receivedDups: 0
receivedUnsolicited: 0
sentTS: 2018-06-09 09:05:53:493
receivedTS: 2018-06-09 09:05:53:361
lastRequestRTT: 26
averageRequestRTT: 26
lastResponseRTT: 37
averageResponseRTT: 37
friendly_name: Garage Door Opener
I’ve read older threads about the Linear garage door opener, which included building or patching a custom openzwave library, but I’d prefer not to get that deep into the weeds if avoidable, and I’m not even sure that applies to hassio. Any suggestions are appreciated, as always. Cheers, Kevin
In order to operate the door remotely you have to install either the custom openzwave_python via github or use the pip command to install the ozwdev flavor. There is no other way.
As for how to do this on Hass.io I believe it was already posted in the zwave section thread.
Thanks, I’ll check this out again. Appreciate the feedback.
