djiesr
(Jean-Sébastien Roux)
January 11, 2023, 5:29pm
1
I want the current consommation of Québec, the data is avalable to https://www.hydroquebec.com/data/documents-donnees/donnees-ouvertes/json/demande.json
and it look like that:
"dateStart" : "2023-01-10T00:00:00",
"dateEnd" : "2023-01-12T00:00:00",
"recentHour" : "2023-01-11T10:45:00",
"indexDonneePlusRecent" : 139,
"nbDateAvecData" : 140,
"details" : [ {
"date" : "2023-01-10T00:00:00",
"valeurs" : {
"demandeTotal" : 25842.0
"date" : "2023-01-10T00:15:00",
"valeurs" : {
"demandeTotal" : 25625.0
"date" : "2023-01-10T00:30:00",
"valeurs" : {
"demandeTotal" : 25509.0
"date" : "2023-01-10T00:45:00",
"valeurs" : {
"demandeTotal" : 25431.0
"date" : "2023-01-10T01:00:00",
"valeurs" : {
"demandeTotal" : 25448.0
My script is:
- platform: rest
name: Hydro-Québec Demande Totale
resource: https://www.hydroquebec.com/data/documents-donnees/donnees-ouvertes/json/demande.json
value_template: '{{ value_json.details[indexDonneePlusRecent].valeurs.demandeTotal }}'
unit_of_measurement: 'MW'
scan_interval: 900
But it’s doesn’t work, I think “indexDonneePlusRecent” didn’t return the number. Someone can help me?
When I use the link above it throws an error,
Try to add logging for the rest component (in confyaml > logger section add homeassistant.components.rest : debug) and see if it actually loads the data
freshcoast
(Z-Wave AI Bot)
January 11, 2023, 5:48pm
3
is a field in value_json
, but you’re not using that, you’re referencing an undefined variable named indexDonneePlusRecent
. You need to index the array using the field:
value_template: '{{ value_json.details[value_json.indexDonneePlusRecent].valeurs.demandeTotal }}'
You can experiment with this template code in the template editor by creating a variable with the expected JSON data :
{% set value_json = {
"indexDonneePlusRecent" : 1,
"details" : [ {
"valeurs" : {
"valeurs" : {
"valeurs" : {
"valeurs" : {
"valeurs" : {
djiesr
January 11, 2023, 6:12pm
4
Thanks! It’s good to know.
