Makis
(Makis)
May 29, 2020, 6:47pm
1
I have the following script
go_to_bed:
alias: Goodnight
icon: mdi:bed-empty
sequence:
- service: automation.trigger
entity_id:
- automation.set_alarm_at_night
- service: light.turn_on
entity_id: light.bedside_lamp
- service: cover.close_cover
entity_id:
- cover.50758014840d8e91f4fd #window1
- delay: '00:00:40'
entity_id:
- cover.50758014840d8e91f036 #window
- delay: '00:00:10'
entity_id:
- cover.50758014840d8e91eaa2 #bedroom
- delay: '00:00:15'
entity_id:
- cover.50758014840d8e918632 #kid
- delay: '00:00:02'
and I would like to add a condition to close each cover IF it’s state is “open” or “unknown”
something like this
condition:
condition: or
conditions:
- condition: state
entity_id: cover.50758014840d8e918614
state: "unknown"
- condition: state
state: "open"
Will this work? Because if I understand right if one cover is closed (state “closed”) it will not continue to execute the rest of the script.
While executing a script you can add a condition to stop further execution.
When a condition does not return true, the script will stop executing.
Is there an alternative way to add the condition?
thoughton
(Tim Houghton)
May 30, 2020, 1:47am
2
You could make a separate script with the condition for each cover, then in your goodnight script call the 4 cover scripts.
Or one script that takes a variable:
go_to_bed:
alias: Goodnight
icon: mdi:bed-empty
sequence:
entity_id:
- service: script.close_cover
entity_id: cover.50758014840d8e91f4fd #window1
- delay: '00:00:40'
entity_id: cover.50758014840d8e91f036 #window
- delay: '00:00:10'
entity_id: cover.50758014840d8e91eaa2 #bedroom
- delay: '00:00:15'
entity_id: cover.50758014840d8e918632 #kid
- delay: '00:00:02'
close_cover:
sequence:
- condition: template
value_template: "{{ states(entity_id) in ['open', 'unknown'] }}"
data_template:
entity_id: "{{ entity_id }}"
Makis
(Makis)
May 31, 2020, 7:19am
5
That’s a lot better! I will try it and let you know. As I can see I just have to add the new script and change service. I hope that it will work.
Makis
(Makis)
May 31, 2020, 10:03pm
6
Just run the script. Something is wrong so none of the covers worked.if you see something please let me know.
Can you post the YAML code exactly as you have it?
Do you see any warnings or errors in the log?
Makis
(Makis)
June 1, 2020, 4:01pm
8
here it is. in the end I am trying to get a notification to my phone if something is still open-on but although it is working in the dev tools it is not working in the script yet
go_to_bed:
alias: Goodnight
icon: mdi:bed-empty
sequence:
entity_id:
entity_id:
- delay: '00:00:40'
entity_id:
- delay: '00:00:10'
entity_id:
- delay: '00:00:15'
entity_id:
- delay: '00:00:02'
- service: homeassistant.turn_off
entity_id:
- media_player.lg_tv_webos_2
- climate.living_room_ac
#- delay: '00:00:02'
- switch.book
- switch.book_and_door_book_2
- delay: '00:00:02'
entity_id:
- light.77626641ecfabc96e072
- light.77626641ecfabc976395
- switch.k1_kitchen
- switch.balcony_main_switch
- switch.balcony_balcony_1
- switch.balcony_balcony_2
- switch.kid_balcony
- switch.bedroom_balcony
- switch.trapezaria
- switch.k1_kitchen_spot
- switch.book_and_door_door
- delay: '00:00:02'
entity_id:
- switch.sonoff_1000a05283
- switch.sonoff_10009bd11e
- switch.sonoff_10001bb5c7
# - service: notify.pushbullet_notification
# data:
# title: 'What is on'
# message:
# value_template: >
# {{ states['cover'] | selectattr('state','eq', 'open') | map(attribute='name') | list | join(', ') }}
# {{ states['cover'] | selectattr('state','eq', 'unknown') | map(attribute='name') | list | join(', ') }}
# {{ states['switch'] | selectattr('state','eq', 'on') | map(attribute='name') | list | join(', ') }}
# {{ states['light'] | selectattr('state','eq', 'on') | map(attribute='name') | list | join(', ') }}
close_cover:
sequence:
data_template:
You didn’t do what I suggested. Rather, you passed the entity_id
into the new script as a list, not as a single entity_id
. It won’t work that way. This:
entity_id:
is not the same as this:
Makis
(Makis)
June 1, 2020, 4:43pm
10
I didn’t even noticed, that change. I just spotted the - service: script.close_cover
Thanks. I am 99.99% that it will work this evening. will report back if it ok as a solution
