Question About Sunset and Z-Wave Switch/Automation
Ok - New user, but making headway. This one has me stumped…
Here’s the code -
  • alias: Turn On Living Room Light 1 Hour Before Sunset
    platform: sun
    event: sunset
    offset: “-01:00:00”
    service: homeassistant.turn_on
    entity_id: switch.switch.ge_unknown_type5052_id3031_switch_2
Here’s the error in bootup -
Invalid config for [automation]: Entity ID switch.switch.ge_unknown_type5052_id3031_switch_2 is an invalid entity id for dictionary value @ data[‘action’][0][‘entity_id’]. Got None (See /home/pi/.homeassistant/configuration.yaml:86)
WHY? All the examples look like this. I’m truly puzzled after 2 hours of working on it.
Also - when you set the state in the dev tools, shouldn’t that trigger the automation? Just checking. Need a way to test this stuff.
Any help much appreciated!!
Try using the switch.turn_on instead of home assistant.turn_on.
Thanks for the response! I’ll give it a shot! I’ll see how it goes this evening.
Also - anyone have any input on the testing part of the question?
Thanks!! That worked!! :slight_smile:
