When a constant is used as the value for temperature this works but when a Helper, as seen below, is used it doesn’t work. Is there anyway to format the Helper such that I can dynamically change the value?
heat_nighttime:
alias: Heat Nighttime
sequence:
- service: climate.set_temperature
entity_id: climate.west_end_thermostat
temperature: input_number.west_end_night_sp
mode: single
heat_daytime:
alias: Heat Daytime
sequence:
temperature: input_number.west_end_day_sp
mode: single
