Question about Waze Integration using UI
On my HA installation running on a Pi, I had configured Waze using yaml, with two instances “Home → Work” and “Work → Home” :slight_smile:
Last month I crashed the Pi SD Card without backup :frowning: , so I started a fresh install on a NUC.
In the meantime, the Waze configuration using yaml has become deprecated in favour of a UI based integration. I’ve set up this integration for “Home → Work”, and added it a second time for “Work → Home”. That works, though I think it really is clumsy compared to straightforward yawl definitions…
However, two questions…
1/ How do I edit the start and end locations once the integration is configured?
2/ How can I give them meaningful names? Adding a title: in the configuration as below doesn’t work
      - type: horizontal-stack
        cards:
          - type: sensor
            title: Home to work <= This doen't work
            entity: sensor.waze_travel_time
            graph: line
            detail: 2
