Hello friends!
Can you help me? Its a log from a HA:
Error saving events: (sqlite3.DatabaseError) database disk image is malformed [SQL: INSERT INTO events (event_type, event_data, origin, time_fired, created, context_id, context_user_id, context_parent_id) VALUES (?, ?, ?, ?, ?, ?, ?, ?)] [parameters: (‘state_changed’, ‘{}’, ‘LOCAL’, ‘2020-12-27 20:00:22.049551’, ‘2020-12-27 20:00:22.049551’, ‘18a74fed03b56b18735598ee6c330395’, None, None)] (Background on this error at: http://sqlalche.me/e/13/4xp6)
21:02:00 – Recorder (ERROR) - správa sa prvýkrát vyskytla o 11:57:52 a opakuje sa 2006 krát
Error executing query: (sqlite3.DatabaseError) database disk image is malformed [SQL: INSERT INTO events (event_type, event_data, origin, time_fired, created, context_id, context_user_id, context_parent_id) VALUES (?, ?, ?, ?, ?, ?, ?, ?)] [parameters: (‘timer_out_of_sync’, ‘{“seconds”: 1.1666241400016588}’, ‘LOCAL’, ‘2020-12-27 20:00:58.166654’, ‘2020-12-27 20:00:58.166654’, ‘ff75e2bf1dd91cdd31412c86389363e5’, None, None)] (Background on this error at: http://sqlalche.me/e/13/4xp6)
21:02:00 – Recorder (ERROR) - správa sa prvýkrát vyskytla o 11:57:50 a opakuje sa 2218 krát
Error saving events: (sqlite3.DatabaseError) database disk image is malformed [SQL: INSERT INTO events (event_type, event_data, origin, time_fired, created, context_id, context_user_id, context_parent_id) VALUES (?, ?, ?, ?, ?, ?, ?, ?)] [parameters: (‘timer_out_of_sync’, ‘{“seconds”: 1.1816798900035792}’, ‘LOCAL’, ‘2020-12-27 19:59:27.181667’, ‘2020-12-27 19:59:27.181667’, ‘ff75e2bf1dd91cdd31412c86389363e5’, None, None)] (Background on this error at: http://sqlalche.me/e/13/4xp6)
21:01:30 – Recorder (ERROR) - správa sa prvýkrát vyskytla o 11:57:50 a opakuje sa 212 krát
What das it mean? Where is a problem?
Thank You.
