Hi All,
I have a lot of notifications that will be send. So I created a script to make things easier.
This is the script:
mobile_ha_engine:
alias: "Notify Notify Mobile App Engine"
description: "Notify App Mobile Engine to send messages to my mobile phone"
mode: parallel
variables:
message_var: "{{ '' if message is not defined else message }}"
title_var: "{{ 'not set' if title is not defined else title }}"
subtitle_var: "{{ 'not set' if subtitle is not defined else subtitle }}"
thread_var: "{{ 'home_assistant' if thread_id is not defined else thread_id }}"
sound_var: "{{ 'none' if sound_name is not defined else sound_name }}"
critical_var: "{{ 0 if critical_id is not defined else critical_id }}"
volume_var: "{{ 0 if volume_level is not defined else volume_level }}"
category_var: "{{ 'default' if category is not defined else category }}"
sequence:
- service: notify.mobile_app_peter_iphone
message: "{{ message_var }}"
title: "{{ title_var }}"
subtitle: "{{ subtitle_var }}"
push:
thread-id: "{{ thread_var }}"
sound:
name: "{{ sound_var }}"
critical: "{{ critical_var }}"
volume: "{{ volume_var }}"
category: "{{ category_var }}"
From different automations those variables will be send to the script:
message
title
subtitle
thread_id
sound_name
critical_id
volume_level
category
What I want to make script better to leave parts away when variable is empty.
Is that possible with {% macro %}?
When category, volume, critical, name, subtitle is not given, so variable is empty then leave that part away.
