Question: how to handle JSON payload with multiple items?
I have a weather sensor which collects 5 different items (temperature, humidity, wind speed, rainfall) which I would like to send to HA using MQTT in a JSON string something like this:
  "Weather/patio": {
    "Temperature": "20 C",
    "humidity": "50%",
    "wind speed": "25 kph".
   "rain": "25 mm"
If I were doing it one at a time I might send it to this topic
"Weather/patio/temperature" with this payload "20 C".  And I should
find it via the MQTT explorer with that topic.  But if I use a multiple
items in the payload,  how will they show up in the explorer?
Thanks....RDK
As a message containing a JSON string on a single topic, probably something like this:
{"Weather/patio":{"Temperature":"20 C","humidity":"50%","wind speed":"25 kph","rain":"25 mm"}}
There is a fault in your payload. The . after kph should be a ,
Then you can do this:
mqtt:
    - name: "Temperature"
      state_topic: "your_topic_here"
      value_template: "{{ value_json['Weather/patio']['Temperature'] }}"
      device_class: temperature
      state_class: measurement
      unit_of_measurement: "°C"
    - name: "Humidity"
      value_template: "{{ value_json['Weather/patio']['humidity'] }}"
      device_class: humidity
      unit_of_measurement: "%"
    - name: "Wind Speed"
      value_template: "{{ value_json['Weather/patio']['wind speed'] }}"
      device_class: wind_speed
      unit_of_measurement: "km/h"
    - name: "Rain"
      value_template: "{{ value_json['Weather/patio']['rain'] }}"
      device_class: precipitation
      unit_of_measurement: "mm"
Thank you. I’ll study this and do some experiments…RDK
Side Note: IMHO, using “/” as a key name is super-bad practice but possibly you are not generating this data, only getting it. If it is a key, I would use “Weather_Patio” or “WeatherPatio” or “Weather-Patio” as the “/” and further extraction could be handled different on different systems.
Internally for many JSON parsers tthat is not “Weather/patio” … it is probably “Weather_X2f_patio” … example:
Thanks. Today I got back to this project. For some background, until I get a new Raspberry Pi configured to directly pass the real sensor readings to HA via MQTT, I have set up another Pi to publish some test data in MQTT JSON format:
# sudo apt install python3-paho-mqtt
import paho.mqtt.client as mqtt
    Temp = randrange(30)
    ValTemp = Temp
    client.publish("Weather/Patio/Temperature",  str(Temp))
This is working as I see the data in the HA MQTT-Explorer. I have added this code to the “Studio Code Server”:
mqtt:
    - name: "Patio Sensor"
      state_topic: "Weather/Patio/Temperature"
      value_template: "{{ value_json['Weather/Patio']['Temperature'] }}"
which does seem to connect to the “Patio Sensor” as, on the default dashboard, I see Patio Sensor but “unknown” for value. If I remove the “value_template” line then it works and I see the temperature value. However, I can not seem to move/transfer that sensor onto my personal dashboard??
The data information I posted in the original question and answered by @tom_l would have multiple sensor readings is the same MQTT message:
  "Weather/patio": {
    "humidity": "50%",
    "wind speed": "25 kph",
   "rain": "25 mm"
I modified my Raspberry Pi program to send this MQTT message:
    Value = '"Temperature": ' + str(Temp) + ', "humidity": ' + str(Humid) + ',  "wind speed": ' + str(Wind) + ', "rain": ' + str(Rain)
    client.publish("Weather/Patio/Temperature", Value)
ex:    Value String  "Temperature": 10, "humidity": 8,  "wind speed": 86, "rain": 8
Again, I see the MQTT full message in the MQTT explorer. Here is the code, using @tom_l suggestions, in the “Studio Code Server” for all four sensors:
mqtt:
  - name: "Patio Temperature"
    #  value_template: "{{ value_json['Weather/Patio']['Temperature'] }}"
    - name: "Patio Humidity"
      state_topic: "Weather/Patio/Humidity"
    #  value_template: "{{ value_json['Weather/Patio']['humidity'] }}"
    - name: "Patio Wind Speed"
      state_topic: "Weather/Patio/Wind"
    #  value_template: "{{ value_json['Weather/Patio']['wind speed'] }}"
    - name: "Patio Rain"
      state_topic: "Weather/Patio/RainFall"
    #  value_template: "{{ value_json['Weather/Patio']['rain'] }}"
All four sensors are shown on the default dashboard, but all are “Unknown” with or without the “value_template” line in the code.
Any help, suggestion and comments will be welcomed…RDK
You’re confusing some things:
  • the topic is where you publish the data to. It should be taken literally: if you publish to Weather/patio/Temperature, you need to use that as state_topic for every sensor that you want to use to extract data from the payload.
  • then the payload: this is the data published to the topic. If you want to publish multiple values, the convention (not requirement) is to format the data as JSON. Nothing in the payload is relevant for use in state_topic.
First start by formatting your data as proper JSON:
{"Temperature": 10, "humidity": 8,  "wind speed": 86, "rain": 8}
(this is exactly the data that value_json will be used on)
Then publish it to the topic that makes most sense for this:
client.publish("Weather/Patio",  '{"Temperature": 10, "humidity": 8,  "wind speed": 86, "rain": 8}')
Then these sensors should work:
    state_topic: "Weather/Patio"
    value_template: "{{ value_json['Temperature'] }}"
    value_template: "{{ value_json['humidity'] }}"
Many thanks. I’ll get back to this tomorrow. Thanks again.
@robertklep , Thanks. That made sense and worked - many thanks. Now I have to figure out how to give these sensors “unique id”'s. More research…RDK
For example:
    unique_id: patio_temperature
Documented here.
@robertklep , Again many thanks. That worked and I’m able to get them on my personal dashboard. Now I’m trying to modify the output for temperature to be 1 decimal, ie 25.4 vs 25.40. I’ve tried using the float and round functions in my sensor script without effect, if I do nothing it shows 2 decimal places.
      value_template: "{{ value_json.Temperature | round(1)}}"
    #  value_template: "{{ value_json['Temperature'] }}"
What am I doing wrong?
Also I would like to add a time stamp sensor, like “Reading_Time” with a value like ‘14:02:13’ . I published a JSON with that as a payload with this sensor script
    - name: "Reading Time"
      unique_id: patio_time
      value_template: "{{ value_json['Time'] }}"
      device_class: timestamp
but so far also unsuccessful. Any suggestions? …RDK
I’m not 100% sure if you can do this for MQTT sensors, but most sensors have a configurable “Display precision”:
As for the time: what exactly is “unsuccessful”? What does work, and what doesn’t?
Perhaps you need to explicitly convert it:
value_template : "{{ today_at(value_json['Time']) }}"
@robertklep Thanks, I did not think to look as the sensor configuration page. I’m still learning…
For the time stamp idea I sent this as a MQTT payload:
{"Time": "15:40:48", "Temperature": 7, "humidity": 12, "wind": 87, "rain": 7}
and here is my sensor script:
mqtt:
    - name: "Patio Time"
      unique_id: patio_humidity
      unique_id: patio_wind_speed
      value_template: "{{ value_json["wind"] }}"
      unique_id: patio_rain
      value_template: "{{ value_json['rain'] }}"
      unit_of_measurement: "mm"`Preformatted text`
HA is processing the the four (patio_temperature through patio_rain) correctly but that for patio_time returns:
Patio Time /13 minutes ago/ Unknown
I’ve tried a JSON payload both with and without converting the time with str() in my Python pgm and with and without enclosing the time string in quotes. Without success…RDK
