I want to extend the GPIO’s in order to have 1 esp32 do multiple task(s)
I am (re)building my pellet smoker, (bigger/better)
relays to switch the heater,fan(s),auger, lights
read the 6 or 8 thermocouplers
multiple temperature (meat) readers
some controls (buttons and rottary encoder)
LCD screen
wifi
bt proxy
i don’t need everything to be read at 1 exact moment … cycling or reading things 1 by 1 is fine… even the documentation says for example that multiple ADC reading(s) can go wrong … but they don’t give a solution to read in a certain order for example so I need help how to do this.
It is a matter of counting up your devices and how many GPIOs they require. Then see if esp32 is enough. If not, consider what @brooksben11 said, or use more than one esp32.
Pretty open-ended question. I haven’t actually used a multiplexer with ESPHome, so I can’t provide any specific examples. But the YAML is going to be specific to what device you end up getting.
I’d start with searching the ESPHome website for supported multiplexers and go from there.
