Question ili9341 1.8"
has anyone been able to make the ili9341 1.8" work with Esphome, on a wemos d1 mini?
Got a link for that?
a link to the ili9341?
I don’t see a 1.8" ili9341. For the 1.8 it says st7735s.
You are absolutely correct, i didnt catch that. In that case did anyone manage to get the st7735s to work. Ill go try it as well
hello,
yep! with a esp-wroom-32 works great :
esphome:
esp32:
  board: esp-wrover-kit
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "/xxxxxxxxxxxxxKU+L/rxFE="
ota:
  password: "xxxxxxxxx97a25"
wifi:
  ssid: !secret wifi_ssid
  password: !secret wifi_pwd
  manual_ip:
    static_ip: 192.168.1.xx
    gateway: 192.168.1.1
    subnet: 255.255.255.0
    dns1: 192.168.1.1
  fast_connect: on
  power_save_mode: none
i2c:
  sda: GPIO21
  scl: GPIO22
  scan: True
time:
  - platform: homeassistant
    timezone: UTC-4
binary_sensor:
  - platform: status
    name: "Status Wifi Capteur DoucheHaut"
    entity_id: binary_sensor.somebody_home
  - platform: wifi_signal
    name: "WiFi Signal Capteur Douche Haut"
    update_interval: 60s
  - platform: bme280
    temperature:
      name: "Temperature Douche Haut"
      oversampling: 16x
    pressure:
      name: "Pression Douche Haut"
    humidity:
      name: "Humidite Douche Haut"
    address: 0x76
    update_interval: 10s
  - platform: adc
    pin: GPIO36
    name: "Luminosite Douche Haut"
    unit_of_measurement: lux
    update_interval: 5s
    filters:
      - lambda: return (( x * 3.3 / 10000.0) * 3000000.0);
    on_value:
      then:
        - light.turn_on:
            brightness: !lambda |-
              return id(illumination_douche_haut).state / 1000.0;
switch:
  - platform: restart
    name: "Restart Douche Haut"
font:
  - file: "arial.ttf"
  - file: "arial.ttf"
  - file: "theboldfont.ttf"
color:
  - id: my_red
    red: 100%
    green: 15%
    blue: 5%
  - id: my_green
    red: 0%
    green: 100%
    blue: 0%
  - id: my_blue
    red: 0%
    green: 0%
    blue: 100%
  - id: my_white
    red: 100%
    green: 100%
    blue: 100%
spi:
  clk_pin: GPIO18
  mosi_pin: GPIO23
image:
  - file: "/config/www/images/HA/douche1.bmp"
    type: RGB24
#    resize: 128x160
output:
  - platform: ledc
    pin: GPIO15
# Example usage in a light
light:
  - platform: monochromatic
    output: backlight_douche
    default_transition_length: 3s
display:
  - platform: st7735
    model: "INITR_18BLACKTAB"
    reset_pin: GPIO17
    cs_pin: GPIO2
    dc_pin: GPIO16
    rotation: 90
    device_width: 128
    device_height: 160
    col_start: 0
    row_start: 0
    eight_bit_color: false
    pages:
      - id: page1
        lambda: |-
          if ((id(illumination_douche_haut).state < 50) | (!id(somebody_home).state)) {
           auto call = id(backlight_st7735_douche).turn_off();
           call.perform();
          } else {
          auto call = id(backlight_st7735_douche).turn_on();
          call.perform();
          it.rectangle(0, 0, 159, 127, id(my_blue));
          it.image(0, 0, id(my_image));
      - id: page2
        lambda: |-
           call.perform();
          } else {
          call.perform();
          it.line(0,  32, 160, 32, id(my_blue));
          it.strftime(20, 10, id(five8), "%H : %M", id(time_ha).now());
          it.strftime(75, 10, id(five8), "%d . %m . %Y", id(time_ha).now());
          it.printf(25, 40, id(five8), "Capteurs Douche Haut");
          it.printf(23, 40, id(five8), "______________________");
          it.printf(10, 60, id(five8), "Temperature ......... %.1f °C", id(temperature).state);
          it.printf(10, 70, id(five8), "Humidite .............. %.1f RH", id(humidity).state);
          it.printf(10, 80, id(five8), "Pression ........... %.1f hPa", id(pressure).state);
          it.printf(10, 90, id(five8), "Luminosite........... %.1f lm", id(illumination_douche_haut).state);
          it.printf(10, 115, id(five8), "Wifi : %s", id(etatWCSDBDh).state ? "Online" : "Offline");
          it.printf(100, 115, id(five8), "%.1f", id(signalWCSDBDh).state);
          it.printf(130, 115, id(five8), "dB");
      - id: page3
        lambda: |-
           call.perform();
          } else {
          call.perform();
          it.line(0,  50, 160, 50, id(my_blue));
          it.strftime(50, 40, id(five15), TextAlign::BASELINE_LEFT, "%H : %M", id(time_ha).now());
          it.strftime(3, 95, id(five15), TextAlign::BASELINE_LEFT, "%d . %m . %Y", id(time_ha).now());
      - id: page4
        lambda: |-
           call.perform();
          } else {
          call.perform();
          it.line(0,  64, 160, 64, id(my_blue));
          it.printf(50, 20, id(five15), "%.1f °C", id(temperature).state);
          it.printf(45, 80, id(five15), "%.1f RH", id(humidity).state);
interval:
  - interval: 5s
    then:
      - display.page.show_next: douche_display
      - component.update: douche_display
i have a photoresistor powered to 3.3v, connected to GPio36 thats control the backlight of the screen, need a resistor 10k between Gpio36 to ground too.
You need to download the font files in .tts of the font i used in this config but you can used any font you want , just download them in esphome folder under config.
the screen light up only if somebody_home is true AND if the ambiant light is above 50 lux.
Enjoy
Thank you so much for the config Olivier, this helps a lot.
i see if i can use this on a d1 mini as well :slight_smile:
nope, doent work, never succeed with a d1 mini
I got my idea from here,
https://www.printables.com/model/169291-case-for-esp8266-d1-mini-and-177-tft
he doesnt give his code?
I messaged him a few days back but no response.
so bad…no feedback doesnt help the community…
he replied yesterday, hes traveling at the moment, i will give you a update once i have it :slight_smile:
This is the message:
Hi, this was definitely not my original idea, I can’t remember where I saw something similar - probably on Reddit… But anyways, I used this display: 1.8 1.77 Zoll TFT 128x160 SPI ST7735 Display Anzeige Arduino Raspberry Pi - MAKERSHOP.DE
On the TFT’s PCB there’s are 14 connection pads, but only the first 8 are used. I have them connected like this:
1 → G, 2 → 3V3, 3 → D5, 4 → D6, 5 → D3, 6 → D2, 7 → D1, 8 → D4.
And this is the basic code for the display I’m using in ESPHome (you might have to change the display model, depending on the version you have):
api:
output:
  • platform: esp8266_pwm
    pin: D4
    frequency: 1000 Hz
light:
  • platform: monochromatic
    output: pwm_output
    name: “TFT backlight”
display:
  • platform: st7735
    model: “INITR_18BLACKTAB”
    reset_pin: D3
    cs_pin: D1
    dc_pin: D2
    rotation: 0
    device_width: 128
    device_height: 160
    col_start: 0
    row_start: 0
    eight_bit_color: true
    update_interval: 5s
    lambda: |-
You can then pull basically what ever data from HA you want, for example something like this:
time:
  • platform: homeassistant
…and then show it on the display using the lambda function:
lambda: |-
  it.line(0, 35, 128, 35);
  it.strftime(0, 0, id(font_big), "%H:%M", id(esptime).now());
I just used google to find the bits I needed, but everything’s really pretty simple. I think I used this as a starting point: Time & Temperature on OLED Display — ESPHome
I hope this helps to get you started. :slight_smile:
thanks a lot!
but its not ili9341 lol
i already succeed with a st7735 1.44 and 1.77 without any problem, bit it doent work with an ili9341 display and a wemos D1 mini or boards with esp8266, i only succeed with an esp32
That is where i am stuck as well.
I cant get it to work with a d1 mini at all. He did somehow :exploding_head:
would it be possible for you to share your code from the St7735 on a esp32? as i might just switch to that one if this one doesn’t work.
lol
my code is already a few post above :wink:
The docs do say
it is better suited for use with the ESP32.
So far this is what managed to get to work:
For anyone interested, here is the code:
esphome:
esp8266:
  board: d1_mini_pro
# Enable logging
logger:
# Enable Home Assistant API3
api:
ota:
  password: "0b4e2b317e57ed139ebc9b1a38a28d4d"
wifi:
  ap:
    ssid: "Display01 Fallback Hotspot"
    password: "iMF5pnYxPJaY"
captive_portal:
spi:
  clk_pin: D5
  mosi_pin: D7
font:
  - file: 'arial.ttf'
  - file: 'materialdesignicons-webfont.ttf'
    glyphs:
      - "󰖩"# mdi:wifi
      - "󱚵"# mdi:wifi-alert
   # Weather
      - "󰖙" # mdi-weather-sunny
      - "󰖔" # mdi-weather-night
      - "󰖐" # mdi-weather-cloudy
      - "󰖖" # mdi-weather-pouring
      - "󰙿" # mdi-weather-snowy-rainy
      - "󰼶" # mdi-weather-snowy-heavy
      - "󰖞" # mdi-weather-windy-variant
      - "󰖑" # mdi-weather-fog
      - "󰖕" # mdi-weather-partly-cloudy
      - "󰼱" # mdi-weather-night-partly-cloudy
time:
    entity_id: sensor.living_room_temperature
    entity_id: sensor.outside_temperature
binary_sensor:
    entity_id: binary_sensor.internet_status
    entity_id: binary_sensor.motion_detector_garage_2
  - platform: status
text_sensor:
    entity_id: sensor.brigitte_location
    entity_id: sensor.dayoftheweek
    entity_id: sensor.shortdate
    entity_id: sensor.weather
color:
  - id: red
    red: 100%
    green: 0%
    blue: 0%
    white: 0%
  - id: green
    red: 0%
    green: 100%
    blue: 0%
    white: 0%
  - id: blue
    red: 0%
    green: 0%
    blue: 100%
    white: 0%
  - id: white
    red: 0%
    green: 0%
    blue: 0%
    white: 100%
  - id: yellow
    red: 100%
    green: 100%
    blue: 0%
    white: 100%
graph:
  - id: multi_temperature_graph
    duration: 2h
    x_grid: 10min
    y_grid: 1.0     # degC/div
    width: 87
    height: 51
    traces:
      - sensor: inside_temperature
        line_type: SOLID
        line_thickness: 2
        color: red
      - sensor: outside_temperature
        line_type: SOLID
        line_thickness: 2
        color: blue
display:
  - platform: st7735
    reset_pin: D3
    cs_pin: D2
    dc_pin: D4
    rotation: 0
    device_width: 128
    device_height: 160
    col_start: 0
    row_start: 0
    update_interval: 5s
    lambda: |-
      // Print "Temperature" in top center.
      it.printf(64, 0, id(font1), blue,  TextAlign::TOP_CENTER, "Temperature");
      // Print time in HH:MM format
      it.strftime(0, 62, id(font1), TextAlign::BASELINE_LEFT, "%H:%M", id(esptime).now());
      it.line(0, 63, 41, 63);
      // Print inside temperature (from homeassistant sensor)
      it.printf(128, 12, id(font1), TextAlign::TOP_RIGHT , "%.1f°", id(inside_temperature).state);
      if (id(inside_temperature).state < 8) {
      it.printf(128, 12, id(font1), blue, TextAlign::TOP_RIGHT, "%.1f°", id(inside_temperature).state);
      if (id(inside_temperature).state > 25) {
      it.printf(128, 12, id(font1), red, TextAlign::TOP_RIGHT, "%.1f°", id(inside_temperature).state);
      // Print outside temperature (from homeassistant sensor)
      it.printf(128, 37, id(font1), TextAlign::BASELINE_RIGHT , "%.1f°", id(outside_temperature).state);
      if (id(outside_temperature).state < 8) {
      it.printf(128, 12, id(font1), blue, TextAlign::TOP_RIGHT, "%.1f°", id(outside_temperature).state);
      if (id(outside_temperature).state > 25) {
      it.printf(128, 12, id(font1), red, TextAlign::TOP_RIGHT, "%.1f°", id(outside_temperature).state);
      it.line(0, 38, 128, 38);
      // Print Inside temperature.
      it.printf(0, 24, id(font1), yellow, TextAlign::BASELINE_LEFT, "Inside");
      // Print outside temperature.
      it.printf(0, 37, id(font1), yellow, TextAlign::BASELINE_LEFT, "Outside");
      // Print "Time" in top center.
      it.printf(0, 37, id(font1), blue, TextAlign::TOP_LEFT, "Time");
      // Draw the graph at position.
      it.graph(41, 38, id(multi_temperature_graph));
      // Print wifi status.
      it.printf(0, 62, id(font1), blue, "Wifi");
      it.printf(0, 74, id(font1), "%s", id(internet_status).state ? "Online" : "Offline");
      it.line(0, 88, 40, 88);
      // Print motion detector status.
      it.printf(0, 87, id(font1), blue, "Motion");
      it.printf(0, 99, id(font1), yellow, "%s", id(outside_status).state ? "Detected" : "Clear");
      it.line(0, 113, 128, 113);
      // Print vertical line.
      it.line(57, 113, 57, 88);
      // Print date status.
      it.printf(58, 87, id(font1), blue, "Date");
      it.printf(58, 99, id(font1), red, "%s", id(day).state.c_str());
      it.printf(83, 99, id(font1), yellow, "%s", id(date).state.c_str());
      // Print person status.
      it.printf(0, 112, id(font1), blue, "Brigitte");
      it.printf(0, 125, id(font1), yellow, "%s", id(brigitte_location).state.c_str());
      //test
      if (id(weather).has_state()) {
          std::map<std::string, std::string> weather_state {
              { "sunny", "󰖙" },             // mdi:weather-sunny
              { "night", "󰖔" },           // mdi:weather-night
              { "cloudy", "󰖐" },                // mdi:weather-cloudy
              { "rain", "󰖖" },                  // mdi:weather-pouring
              { "sleet", "󰙿" },                 // mdi:weather-snowy-rainy
              { "snow", "󰼶" },                  // mdi:weather-snowy-heavy
              { "wind", "󰖞" },                  // mdi:weather-windy-variant
              { "fog", "󰖑" },                   // mdi:weather-fog
              { "partlycloudy", "󰖕" },          // mdi:weather-partly-cloudy
              { "partlycloudynight", "󰼱" },   // mdi:weather-night-partly-cloudy
            it.printf(92, 112, id(icons), weather_state[id(weather).state.c_str()].c_str());
