I have an automation that is triggered by a humidity change.
There is then a condition to check if the humidity is above or below a certain level.
If it is above, then it turns on an extractor fan, waits for 5 minutes, then turns it off.
Its mode is set to restart, meaning that on the next humidity change, if thats within 5 minutes, it kills the previous automation run and starts again.
If the humidity remains high, the 5 minute wait is effectively refreshed and the fan stays on.
However, I’m not clear what happens if the condition is not met.
Does mode: restart mean that the previous automation, if still running, is ALWAYS stopped, even if the next run does not actually initiate any actions because the condition is not met ?
Or, is the previous run only stopped if the next run meets its run condition ?
The reason I am unsure is because the screen shot here:-
Shows how actions are effected, not triggers and conditions.
