Hi all,
I’ve been pulling my hair quite abit for this problem, I have my HA on RPi4 configured to use cloudflared tunnel with https://home-assitant.domain.com
> https://home-assitant.domain.com:8123
On the companion app, that’s what I put too https://home-assitant.domain.com
It works perfect when I’m connecting from external (On cellular data).
The problem here is when I’m connect from internally, it just won’t work if I dont specify the port ( https://home-assitant.domain.com
instead of https://home-assitant.domain.com:8123
It will just throw me
This site can’t be reached
home-assitant.domain.com refused to connect.
ERR_CONNECTION_REFUSED
I’ve tried to use Nginx Proxy Manager
to reverse proxy / redirect but no luck .
Sooo… Can anyone shed some light on what did I do wrong? or What should I look into to make it work?
My AddOn:
- hassio-addons/addon-adguard-home
- @brenner-tobias/addon-cloudflared
- and others Addon for zigbee
Thank you in advance!!
