I setup Dlib component on my HomeAssistant.
It works fine, but is that possible to get the picture analyzed by the component ?
Hi…
I tried this and I get an error platform cannot be setup. Could you please advise me if there is anything more to be done besides just following what is said in the components doc. Thanks in advance.
Hi @KvRajan
I must to do that to avoid errors :
sudo apt-get install cmake
sudo pip3 install face_recognition==0.1.14
After that restart Home Assistant and all works !
The component face_recognition needs cmake to compile dlib.
Hi…
Did you install any library or tool with apt-get for this to work.
Could you please provide the details how you made it work.
Thanks.
Oh ! That’s great and I was looking for such inputs only. Will try it out and revert. Thanks a million.
Hi…
I’m installing face_recognition and it is taking too long. First time, my system Raspberrry PI3 was frozen.
I rebooted it and trying again. Does it really take too long…? say over 15 minutes or so… The last message on the screen is
" Building wheels for collected packages: dlib, scipy
Running setup.py bdist_wheel for dlib … "
Is this normal or something, not right…?
thanks in advance.
Hi…
Further to the above, it came out with the following message:
Failed building wheel for scipy
Failed cleaning build for for scipy
and does not go further. system hangs and need to be rebooted.
Any advice how to get this working. Any pre-requisites missing…?
Hi
I installed that on a Ubuntu VM where home assistant is installed
So not on a raspberry
Any messages in syslog ?
Hi…
Bad luck in installing face_recognition. Did not go through. I tried on another PI. Got stuck somewhere in the middle and stopped.
Could you please advise what messages to look for and where ?
thanks in advance.
I tried installing dlib on my Pi3, it was compiling it’s modules for three hours before it finally failed. I just assumed it wasn’t something that could run on a Pi.
Same problem here!
Enclosed the log and yaml!
camera:
image_processing:
017-05-22 23:01:46 ERROR (MainThread) [homeassistant.helpers.entity] Update for image_processing.dlib_face_local_file fails
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/entity.py”, line 222, in async_update_ha_state
yield from self.async_update()
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/image_processing/init.py”, line 140, in async_update
yield from self.async_process_image(image)
File “/usr/lib/python3.4/asyncio/futures.py”, line 388, in iter
yield self # This tells Task to wait for completion.
File “/usr/lib/python3.4/asyncio/tasks.py”, line 286, in _wakeup
value = future.result()
File “/usr/lib/python3.4/asyncio/futures.py”, line 277, in result
raise self._exception
File “/usr/lib/python3.4/concurrent/futures/thread.py”, line 54, in run
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/image_processing/dlib_face_detect.py”, line 71, in process_image
self.process_faces(face_locations, len(face_locations))
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/image_processing/microsoft_face_identify.py”, line 111, in process_faces
self.hass.loop, self.async_process_faces, faces, total).result()
File “/usr/lib/python3.4/concurrent/futures/_base.py”, line 395, in result
return self.__get_result()
File “/usr/lib/python3.4/concurrent/futures/_base.py”, line 354, in __get_result
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/util/async.py”, line 167, in run_callback
future.set_result(callback(*args))
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/image_processing/microsoft_face_identify.py”, line 137, in async_process_faces
face.update({ATTR_ENTITY_ID: self.entity_id})
AttributeError: ‘tuple’ object has no attribute ‘update’
Same errors occuring here. It seems to happen when it does see a face.
For me none errors in the logs even if it doesn’t detect face…
Same here!
2017-07-15 20:43:39 ERROR (MainThread) [homeassistant.helpers.entity] Update for image_processing.dlib_face_garage fails
File "/usr/local/lib/python3.5/dist-packages/homeassistant/helpers/entity.py", line 222, in async_update_ha_state
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/image_processing/__init__.py", line 140, in async_update
File "uvloop/future.pyx", line 230, in __iter__ (uvloop/loop.c:110600)
File "uvloop/future.pyx", line 432, in uvloop.loop.BaseTask._fast_wakeup (uvloop/loop.c:113980)
File "uvloop/future.pyx", line 101, in uvloop.loop.BaseFuture._result_impl (uvloop/loop.c:108900)
File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/image_processing/dlib_face_detect.py", line 71, in process_image
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/image_processing/microsoft_face_identify.py", line 111, in process_faces
File "/usr/lib/python3.5/concurrent/futures/_base.py", line 405, in result
File "/usr/lib/python3.5/concurrent/futures/_base.py", line 357, in __get_result
File "/usr/local/lib/python3.5/dist-packages/homeassistant/util/async.py", line 167, in run_callback
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/image_processing/microsoft_face_identify.py", line 137, in async_process_faces
AttributeError: 'tuple' object has no attribute 'update'
@patvdleer yes I found this bug too and I’m testing/working on a fix now.
If you want, you can test this debug code at https://github.com/tchellomello/home-assistant/tree/dlib_troubleshooting
Could you report this issue as an official problem? The branch above should take care of this problem. Dlib is working for me now and I’m also working on extending some options.
One of the options that I’m also testing is an ability see the images that are being captured or ignore by dlib. To do this, I’ve extended the component to save the image on some different conditions. So if an image has a face it will be saved on a directory when the option keep _images_with_faces
is True
. When keep_images_without_faces
is True, all captured images also will saved in case a not face recognized.
The second part is with face identification. If is a known face combined with the option ‘keep_known_faces’ the image will be saved too. And pictures with faces but without a known face will also be saved that will help to understand the precise the sensor is. Of course this is intended to be used on debug and maybe we need to come with better names. Please let me know if you think this is useful. For me it was.
- platform: dlib_face_detect
keep_images_with_faces: True
keep_images_without_faces: False
source:
- entity_id: camera.amcrest_driveway
name: "Face Detection"
- platform: dlib_face_identify
keep_known_faces: True
keep_unknown_faces: True
source:
name: "Face Identification"
faces:
mmello: /home/hass/.homeassistant/faces/mmello.png
mmello-fail: /home/hass/.homeassistant/faces/mmello-fail.jpg
The directories will be created automatically under the same directory where configuration.yaml
file is sitting on. For example:
(ha-py36) ↪ ll /home/mdemello/.homeassistant_tests/
total 3.4M
-rw-rw-r--. 1 mdemello mdemello 269 Jul 15 02:08 automations.yaml
-rw-rw-r--. 1 mdemello mdemello 689 Jul 11 03:23 cameras.yaml
-rw-rw-r--. 1 mdemello mdemello 897 Jul 15 00:09 configuration.yaml
drwxrwxr-x. 32 mdemello mdemello 4.0K Jul 11 01:19 deps/
drwxrwxr-x. 2 mdemello mdemello 20K Jul 15 02:08 dlib_detect_with_faces/
drwxrwxr-x. 2 mdemello mdemello 20K Jul 15 02:08 dlib_detect_without_faces/
drwxrwxr-x. 2 mdemello mdemello 4.0K Jul 15 02:08 dlib_identify_known_faces/
drwxrwxr-x. 2 mdemello mdemello 20K Jul 15 02:08 dlib_identify_unknown_faces/
-rw-rw-r--. 1 mdemello mdemello 0 Jul 9 23:47 groups.yaml
-rw-rw-r--. 1 mdemello mdemello 534K Jul 15 02:08 home-assistant.log
-rw-r--r--. 1 mdemello mdemello 2.8M Jul 15 02:08 home-assistant_v2.db
-rw-rw-r--. 1 mdemello mdemello 517 Jul 15 00:31 image_processing.yaml
drwxrwxr-x. 2 mdemello mdemello 4.0K Jul 11 01:18 python_scripts/
-rw-rw-r--. 1 mdemello mdemello 4.0K Jul 9 23:50 secrets.yaml
-rw-rw-r--. 1 mdemello mdemello 146 Jul 15 00:11 switches.yaml
Please let me know if that worked for you.
mmello
The issue has been reported, I’ll checkout the branch after lunch and see if I can dive in the code and help you fix it.
https://github.com/home-assistant/home-assistant/issues/8493
Can you confirm if the issue is fixed in 0.49?
@patvdleer I’ve submitted the PR https://github.com/home-assistant/home-assistant/pull/8515 to address this problem.
Please refer to the PR for further information on how to configure it if you want to test it.
mmello
Hi…
While installing cmake, I get the following error… Could some one help me fix this.? Thanks in advance.
The installation is being done on Raspberry PI3 -All-in-one HA …
CMake Error at /tmp/pip-build-mu96tn0d/dlib/dlib/cmake_utils/add_python_module:116
(message):
Boost python library not found.
Call Stack (most recent call first):
CMakeLists.txt:6 (include)
– Configuring incomplete, errors occurred!
See also "/tmp/pip-build-
mu96tn0d/dlib/tools/python/build/CMakeFiles/CMakeOutput.log".
error: cmake configuration failed!
–compile" failed with error code 1 in /tmp/pip-build-mu96tn0d/dlib/
