I tried installing dlib on my Pi3, it was compiling it’s modules for three hours before it finally failed. I just assumed it wasn’t something that could run on a Pi.
Same problem here!
Enclosed the log and yaml!
camera:
- platform: local_file
file_path: /tmp/image.jpg
image_processing:
- platform: dlib_face_detect
source:- entity_id: camera.local_file
017-05-22 23:01:46 ERROR (MainThread) [homeassistant.helpers.entity] Update for image_processing.dlib_face_local_file fails
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/entity.py”, line 222, in async_update_ha_state
yield from self.async_update()
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/image_processing/init.py”, line 140, in async_update
yield from self.async_process_image(image)
File “/usr/lib/python3.4/asyncio/futures.py”, line 388, in iter
yield self # This tells Task to wait for completion.
File “/usr/lib/python3.4/asyncio/tasks.py”, line 286, in _wakeup
value = future.result()
File “/usr/lib/python3.4/asyncio/futures.py”, line 277, in result
raise self._exception
File “/usr/lib/python3.4/concurrent/futures/thread.py”, line 54, in run
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/image_processing/dlib_face_detect.py”, line 71, in process_image
self.process_faces(face_locations, len(face_locations))
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/image_processing/microsoft_face_identify.py”, line 111, in process_faces
self.hass.loop, self.async_process_faces, faces, total).result()
File “/usr/lib/python3.4/concurrent/futures/_base.py”, line 395, in result
return self.__get_result()
File “/usr/lib/python3.4/concurrent/futures/_base.py”, line 354, in __get_result
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/util/async.py”, line 167, in run_callback
future.set_result(callback(*args))
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/image_processing/microsoft_face_identify.py”, line 137, in async_process_faces
face.update({ATTR_ENTITY_ID: self.entity_id})
AttributeError: ‘tuple’ object has no attribute ‘update’
Same errors occuring here. It seems to happen when it does see a face.
For me none errors in the logs even if it doesn’t detect face…
Same here!
2017-07-15 20:43:39 ERROR (MainThread) [homeassistant.helpers.entity] Update for image_processing.dlib_face_garage fails
File "/usr/local/lib/python3.5/dist-packages/homeassistant/helpers/entity.py", line 222, in async_update_ha_state
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/image_processing/__init__.py", line 140, in async_update
File "uvloop/future.pyx", line 230, in __iter__ (uvloop/loop.c:110600)
File "uvloop/future.pyx", line 432, in uvloop.loop.BaseTask._fast_wakeup (uvloop/loop.c:113980)
File "uvloop/future.pyx", line 101, in uvloop.loop.BaseFuture._result_impl (uvloop/loop.c:108900)
File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/image_processing/dlib_face_detect.py", line 71, in process_image
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/image_processing/microsoft_face_identify.py", line 111, in process_faces
File "/usr/lib/python3.5/concurrent/futures/_base.py", line 405, in result
File "/usr/lib/python3.5/concurrent/futures/_base.py", line 357, in __get_result
File "/usr/local/lib/python3.5/dist-packages/homeassistant/util/async.py", line 167, in run_callback
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/image_processing/microsoft_face_identify.py", line 137, in async_process_faces
AttributeError: 'tuple' object has no attribute 'update'
@patvdleer yes I found this bug too and I’m testing/working on a fix now.
If you want, you can test this debug code at https://github.com/tchellomello/home-assistant/tree/dlib_troubleshooting
Could you report this issue as an official problem? The branch above should take care of this problem. Dlib is working for me now and I’m also working on extending some options.
One of the options that I’m also testing is an ability see the images that are being captured or ignore by dlib. To do this, I’ve extended the component to save the image on some different conditions. So if an image has a face it will be saved on a directory when the option keep _images_with_faces
is True
. When keep_images_without_faces
is True, all captured images also will saved in case a not face recognized.
The second part is with face identification. If is a known face combined with the option ‘keep_known_faces’ the image will be saved too. And pictures with faces but without a known face will also be saved that will help to understand the precise the sensor is. Of course this is intended to be used on debug and maybe we need to come with better names. Please let me know if you think this is useful. For me it was.
keep_images_with_faces: True
keep_images_without_faces: False
source:
- entity_id: camera.amcrest_driveway
name: "Face Detection"
- platform: dlib_face_identify
keep_known_faces: True
keep_unknown_faces: True
source:
name: "Face Identification"
faces:
mmello: /home/hass/.homeassistant/faces/mmello.png
mmello-fail: /home/hass/.homeassistant/faces/mmello-fail.jpg
The directories will be created automatically under the same directory where configuration.yaml
file is sitting on. For example:
(ha-py36) ↪ ll /home/mdemello/.homeassistant_tests/
total 3.4M
-rw-rw-r--. 1 mdemello mdemello 269 Jul 15 02:08 automations.yaml
-rw-rw-r--. 1 mdemello mdemello 689 Jul 11 03:23 cameras.yaml
-rw-rw-r--. 1 mdemello mdemello 897 Jul 15 00:09 configuration.yaml
drwxrwxr-x. 32 mdemello mdemello 4.0K Jul 11 01:19 deps/
drwxrwxr-x. 2 mdemello mdemello 20K Jul 15 02:08 dlib_detect_with_faces/
drwxrwxr-x. 2 mdemello mdemello 20K Jul 15 02:08 dlib_detect_without_faces/
drwxrwxr-x. 2 mdemello mdemello 4.0K Jul 15 02:08 dlib_identify_known_faces/
drwxrwxr-x. 2 mdemello mdemello 20K Jul 15 02:08 dlib_identify_unknown_faces/
-rw-rw-r--. 1 mdemello mdemello 0 Jul 9 23:47 groups.yaml
-rw-rw-r--. 1 mdemello mdemello 534K Jul 15 02:08 home-assistant.log
-rw-r--r--. 1 mdemello mdemello 2.8M Jul 15 02:08 home-assistant_v2.db
-rw-rw-r--. 1 mdemello mdemello 517 Jul 15 00:31 image_processing.yaml
drwxrwxr-x. 2 mdemello mdemello 4.0K Jul 11 01:18 python_scripts/
-rw-rw-r--. 1 mdemello mdemello 4.0K Jul 9 23:50 secrets.yaml
-rw-rw-r--. 1 mdemello mdemello 146 Jul 15 00:11 switches.yaml
Please let me know if that worked for you.
mmello
The issue has been reported, I’ll checkout the branch after lunch and see if I can dive in the code and help you fix it.
https://github.com/home-assistant/home-assistant/issues/8493
Can you confirm if the issue is fixed in 0.49?
@patvdleer I’ve submitted the PR https://github.com/home-assistant/home-assistant/pull/8515 to address this problem.
Please refer to the PR for further information on how to configure it if you want to test it.
mmello
Hi…
While installing cmake, I get the following error… Could some one help me fix this.? Thanks in advance.
The installation is being done on Raspberry PI3 -All-in-one HA …
CMake Error at /tmp/pip-build-mu96tn0d/dlib/dlib/cmake_utils/add_python_module:116
(message):
Boost python library not found.
Call Stack (most recent call first):
CMakeLists.txt:6 (include)
– Configuring incomplete, errors occurred!
See also "/tmp/pip-build-
mu96tn0d/dlib/tools/python/build/CMakeFiles/CMakeOutput.log".
error: cmake configuration failed!
–compile" failed with error code 1 in /tmp/pip-build-mu96tn0d/dlib/
Hi
Have you test tout do that before ?
$sudo apt-get install build-essential cmake
$ sudo apt-get install libgtk-3-dev
$ sudo apt-get install libboost-all-dev
Hi… Thanks for suggesting… Installed those 3 and tried to compile cmake which went through. However, installation of face_recognition failed and HA started hanging / crashed.
Does it really work in a Raspberry PI3 All-in-One HA installation.?
On a Rpi3 i don’t know, for me HA is installed on a VM on a ESX server…
Additional dependencies:
sudo apt-get install libjpeg-dev zlib1g-dev liblapack-dev
Hi all,
for those who made this component work. How well does it work? How high is your accuracy ?
Also, will it be able to do inference on PI? Or need better CPU to run on?
Where did you do model training if any?
How does this component compare to Microsoft Face recognition API? Their model must be better, but I wonder what the latency is for dlib vs Microsoft Face api?
I tested that one year ago…
The Microsoft solution is connected to microsoft server i prefer avoid this type of architecture.
Nevertheless this solution is quite quickly.
I test DLIB component and on a correct server (XEON 3.9ghz) on a VM, it takes 4-5 seconds to recognize somebody and execute an automation.
For me it’s not enough quick to be integrated to my system… but it is fun
Have no idea how to get it work on Hassio on RPI3.
After container restarting installed packages (cmake and face_recognition) gone.
If you have a configuration that works on a normal install (not container based) and are willing to share that, I will figure out the container resolution. It maybe just mapping some files that’s required, similar to the t solution for Zwave configuration
Regards
Damian
Hey… i wonder if the configuration options keep_images_with faces and so on have it ever made into the master branch? I do not see those configuration options in the dlib documentation - why is that?
Also i tried to use this component on a Raspberry Pi3 but it slowed down the hole system - but the strange thing was that it did not take CPU or memory resources, so i don’t really understand why it almost blocked my Raspberry. This should not be an IO intensive task, right?
Has anyone achived to got this smoothly running on an RPi3 with camera.local_file as source?
