I jumped in to Home Assistant world around three months ago. I have been tweaking the system in configuration wise but also tried to create the lovelace that I like to use.
Question: how I create the mardown card which uses the current background color?
I have tried to find the answer from the community with no success.
I’m not sure, maybe it could be done with the theme as well, but then it would apply to all cards, so you’d need to change other cards to have a background.
Could you please mark my post as the solution? This way others will find the solution quickly and the topic will be marked as solved.
