Question/request : How to use datactl on the latest version?
Hi all,
i try to use datactl on my installation which uses a PiDrive.
as mentionned in the following link
Documentation on Data disk
i will keep the SD card in read only mode but i failed using the following procedure
Community
i don’t know what i have to enter login command. Could some help me on this topic ?
My setup is a RPI3B+ with a 375Gb Pidrive.
how must the hard drive be formatted FAT32 ? other ?
Thanks for your support
Laurent
Did you ever find out how to use datactl command? When i enter datactl, it says command not found.
I did. The following command worked for me:
ha os datadisk move /dev/sdb
This seems to do the same as what datactl should have done. See here for the docs: Common Tasks - Operating System - Home Assistant
It seems you don’t need debugging mode anymore, you can even do it via GUI now.
