Question. Smartthings wifi plug, got password to the plug
So I have a newer smartthings wifi smartplug. I got the password, 1111122222 and it connected to the phone fine at 2.4g. From here, where can I go to change the IP on the plug, etc.
Or, is there a way to get this plug into HA without using the smartthings integ? I no longer have smartthings, got rid of the hub, no integration, totally smartthings free otherwise. Can I still use this plug in HA?
Thanks!
I would also like to know this. I’m about to get a Smartthings connected washer, which has/works via wifi. I find it cumbersome to create a Smartthings account, add the washer, then establish a connection between SmartThings and HA just for a few sensors.
Just like the smartplug mentioned by SandmanXX, can I add the wifi-device straight to HA? Or would that require custom yaml / code to access the devices api or something?
(I hope this bumps the topic up in view of someone who knows if this is possible / doable.)
