netti
(Tim)
December 23, 2025, 6:47am
1
is it possible to have a split between the enterties in the expander card?
Normally I have it like that:
Expander card will not split it. I have a full row. The row will lined under each other:
What do I have to do to get the result in picture one with the expander card? Is it possible with yaml code?
And last question → Is it possible to get the details in the first line of the expander card?
Thanks and have a merry christmas.
Greetings Tim
you Could put the entities inside a horizontal-stack-card or custom:vertical-stack-in-card(horizontal-option)(inside the Expander-Card), the options are endless
Which “details” are you talking about ?, again as above options are endless(almost)
you could(in some cases) use card-mod to set a fix width/height of the entities, if the cards don’t support it
Note: have as a routine of also posting the code of the card you are working with, sure a picture tells alot(of what you have and want, but it’s from details of the code
Read in the first Topic(top-Right corner) of this Community, in regards to “post code”
netti
(Tim)
December 23, 2025, 2:03pm
3
boheme61:
Thanks → horizotal-stack worked.
type: custom:expander-card
title: Rauchmelder
cards:
- type: heading
icon: mdi:alarm-light
heading: Alarmmeldungen
heading_style: subtitle
- type: horizontal-stack
cards:
- type: tile
entity: binary_sensor.mel_ez_rauchmelder_alarm
icon: mdi:smoke-detector-variant-off
color: red
show_entity_picture: false
hide_state: false
vertical: false
features_position: bottom
- type: tile
entity: binary_sensor.mel_eg_ez_nebenstellenalarm
color: red
vertical: false
- type: heading
icon: mdi:list-status
heading: Status
cards:
- type: tile
entity: binary_sensor.mel_eg_ez_status_rauchalarm
icon: mdi:check-decagram
vertical: false
- type: tile
entity: binary_sensor.mel_eg_ez_status_waermealarm
vertical: false
cards:
- type: tile
entity: binary_sensor.mel_eg_ez_status_knx
vertical: false
- type: tile
entity: binary_sensor.mel_eg_ez_draht
vertical: false
- type: heading
icon: mdi:smoke-detector-alert
heading: Störungen
cards:
- type: tile
entity: binary_sensor.eg_ez_storung
vertical: false
- type: tile
entity: binary_sensor.eg_ez_stoerung_rauchkammer
vertical: false
cards:
- type: tile
entity: binary_sensor.mel_eg_ez_batterie
- type: tile
entity: binary_sensor.eg_ez_stoerung_kommunikation_knx
vertical: false
cards:
- type: tile
entity: binary_sensor.eg_ez_stoerung_montage_melder
vertical: false
- type: tile
entity: binary_sensor.mel_eg_ez_stoerung_temperatursensor
- type: heading
icon: mdi:home-alert
heading: Schalter
cards:
- type: tile
entity: switch.mel_ez_rauchmelder_testalarm
vertical: false
- type: tile
entity: switch.eg_ez_signalgeber
vertical: false
- type: tile
entity: button.mel_eg_ez_quiterung_stoerung
vertical: false
- type: heading
icon: mdi:temperature-celsius
heading: Temperaturwert
grid_options:
columns: 12
rows: auto
- type: tile
entity: sensor.mel_eg_ez_temperaturmeldung
vertical: false
grid_options:
columns: 6
rows: 2
grid_options:
rows: auto
columns: 12
expanded: false
title-card-clickable: true
title-card-button-overlay: false
clear: true
animation: false
clear-children: false
My last question was to deifne badges into the title.
I want to bing an icon into the title- left side and some badges.
title: Rauchmelder
*Here I want to put in my Badges*
cards:
Like I do it for the aditional title above:
type: heading
icon: mdi:smoke
heading: Rauchmelder
heading_style: title
badges:
- type: entity
- type: entity
grid_options:
columns: 12
rows: 1
But copy the badges from this title to expander card title will not work.
The target is to do it in one card and not having a title cad + expander card.
Check the Githup-repos about his newly added features( Update the Card first in HACS
I haven’t tried this “new” feature, but a have a bunch of custom:fold-entity-row where this works and even response on card-mod
I assume expander_card has “applied” the same functionality
NOTE: Always check examples and features in Github(for Custom-Cards ) to learn ! before asking questions ( we are not common tape-recorders, records-players, nor AI or google representatives
netti
(Tim)
December 25, 2025, 1:36pm
5
Hello Community,
I checked the community and I found a lot of information. I use google and different forums but i still have some open questions.
I am now able to put more color on my card. It a Demo Card to lern.
title: Test
cards:
- type: entities
entities:
- sensor.backup_backup_manager_state
- sensor.sun_next_dawn
- sensor.sun_next_dusk
style: |
/* Titel */
.header {
flex-direction: row-reverse !important;
padding: 0.8em 0 !important;
.header > .title {
transition: color 0.35s ease, font-size 0.35s ease;
.header.animation.open > .title,
.header.animation.opening > .title
color: blue;
background-color: yellow;
font-size: var(--ha-font-size-xl);
.header.animation.close > .title,
.header.animation.closing > .title
color: green !important;
background-color: blue;
font-size: var(--ha-font-size-xs) !important;
/* Umgebung */
.expander-card.animation.open,
.expander-card.animation.opening {
background-color: red;
.expander-card.animation.close,
.expander-card.animation.closing {
background-color: #C8A2C8;
But I am not able to fill the container with color? I tried so much diffrent things →
outer.conter
children.container
but nothing works.
Could someone give me a hint how i can configuere the box color, text color at box?
I read all the information carefully but i have no clue how to fix:
Expander card for HomeAssistant
And a second question:
I can change the color for the button to green when it is on. (color: green)
Is it possible to have a red one when it is off? And is it possible to have different icons for different status?
- type: tile
entity: switch.dim_eg_wz_gang_dim_sperre
icon: mdi:lock
color: green
hide_state: false
state_content:
- state
- last_updated
vertical: false
Thanks.
Best regards
Tim
Search in the Card_Mod Topics , and templates, for the cards which supports templates
dcapslock
(Darryn Capes-Davis)
December 28, 2025, 8:37am
7
If you want the child cards to take on the background of the outer epxander-card, use the clear-children option.
Other options:
Set CSS variables which the card uses on .outer-contaner { }.
e.g.
style: |
.outer-container {
--card-background-color: yellow;
If what you need to style in a card has no CSS variable, you will need to use card-mod.
netti:
As of version 4.3.0 you can set icon and arrow-color using Javsscript templates using all available function from home-assistant-javascript-templates. Check latest readme for examples and link to functions available (e.g. a template for arrow_color might be [[[ return is_state('light.bed_light', 'on') ? 'yellow' : 'grey' ]]] )
