I just picked up a Shelly1 and a ShellyButton 1 and started toying with them
A bit confused at the beginning but in the end got them in home Assistant with the (I guess) official integration. Took me some time to understand I didnât need MQTT for this, as it uses CoIoT.
I have some questions thoughâŚ
Why, when I enable MQTT on the shellies, are they not picked up by the MQTT integration in Home Assistant? BTW, running HA in a docker container, and Eclipse Mosquitto in another container. I have also MQTT on an Octoprint and this is correctly picked up by the HA MQTT integration. Also, the Shellies are interacting with the MQTT broker, as I could confirm with MQTT ExplorerâŚ
Anyway, I tested the CoIoT way and also installed the âShellies discoveryâ script with HACS. After that, I was able to set up an automation as described here. The automation runs perfectly when I run it manually from the automations list. In this case: toggle the Shelly 1.
I noted however that for this to work, I had to disable again MQTT on the Shelly Button 1.
But it does not react to a button press on the Shelly Button 1. When I enable MQTT on the button and monitor it with MQTT Explorer, I can confirm MQTT messages being sent for each type of button press (1x, 2w, 3x, long).
What am I missing here ? Why does the integration not trigger when I press the Shelly button? Here is the yml of the automation:
- id: '1635426737617'
alias: Lumière salle de bain
description: ''
- platform: device
device_id: a0bbcafa8ea92f6a880860a28587a67c
domain: shelly
type: single
subtype: button
condition: []
- type: toggle
device_id: b2a8659591673be32a005345ec556ceb
entity_id: switch.shelly1_sdb
domain: switch
- service: persistent_notification.create
title: DEBUG
message: Automation Salle de Bain triggered
mode: single
My feeling is this may not be complete, I am missing the âButton single clickâ⌠Seescreenshot below:
Thnx for your ideas
