Hello everyone,
I’m new to Home Assistant and home automation at all and I would appreciate some help with configuring my first sensor.
I am using a Aeotec Z-Stick Gen 5 at a RPi 3 with a Hassbian running and added a Schwaiger 4 in 1 sensor (which seems to be a rebranded Philio PST02-A) via Z-Wave.
In added a screenshot at the bottom to show how this looks in Home Assistant.
First, I want to add configure the door/window sensor and added
to configuration.yaml. Is this correct? Can I tell Home Assistant via “frindly_name” which sensor to use and just use the name I gave the sensor in the overview?
I want to use this sensor now for automation and added the following to configuration.yaml
automation:
- alias: terrace safety
platform: state
entitiy_id: sensor.terrasse_door_open
to: 'open'
service: notify.email_notify
data_template:
title: "Door was opened"
message: "Someone opened the door"
However, check config tells me that this is wrong
Configuration invalid
Error loading /config/configuration.yaml: mapping values are not allowed here
in “/config/configuration.yaml”, line 104, column 11
Could someone help and tell me what I am doing wrong here? Has platform to be template here as well? I would really appreciate if someone could point me to the right direction, maybe give me a link to the right documentation as well. Because going through the getting started section I did not really get how Home Assistant knows which sensor is being configured with an entry and how names and entity_ids are connected…
This doesn’t look correct. does sensor.your_sensor exist? I think you should get rid of the entity_id line and place that in the sensor.your_sensor spot. Also, as a side note, I think you should be looking for the ‘open’ state, not closed state. I’ve heard some devices report outside 23 when closed.
EDIT: For clarification, the entity_id line is for entities that don’t fit into your calculation. Basically, if you want to update a template when an entity updates that is NOT part of your equation, use the entity_id attribute to accomplish that task.
Hey and thank you very much for helping. The terrace was not a real problem, I just translated to English for the forum and missed that once… Anyways, I just go with everything in English now so that there won’t be any problem.
I got rid of the entity_id line and placed that in sensor.your_sensor and Home Assistant seems fine with it.
However, the part with the automation still seems to be wrong, even though I tried to copy your text, @tom_l.
Checking the configuration gives me:
in “/config/configuration.yaml”, line 102, column 3 expected , but found ‘’ in “/config/configuration.yaml”, line 103, column 4
line 102 is the line in which “- alias” is.
Do you guys know what’s wrong?
