Queue ZigBee commands to account for delays
Hey there!
I’m trying to use a Tuya ZigBee IR blaster (TS1201) to control a Lasko tower fan, and have built a script to help me toggle between the different speeds based on the amount of button presses.
However, it seems that the delay between sending the command varies from three to around six seconds, and I was wondering if there could be a way to queue the next repetition of the command until the IR blaster can confirm it has successfully sent the previous one before giving up.
The relevant part of my script is as follows:
set_fan_speed:
  sequence:
    - choose:
        - conditions: "{{ percentage == 0 }}"
          sequence:
            - service: script.turn_off_fan
        - conditions: "{{ percentage == 20 }}"
          sequence:
            - choose:
                - conditions: "{{ is_state('input_select.lasko_fan_speed', 'low') }}"
                  sequence:
                    - repeat:
                        count: 4
                        sequence:
                          - service: zha.issue_zigbee_cluster_command
                              cluster_type: in
                              endpoint_id: 1
                              command: 2
                              ieee: f0:82:c0:ff:fe:fd:f1:d5
                              command_type: server
                              params:
                                code: 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
                              cluster_id: 57348
                          mode: single
                          - delay: "00:00:03"
                - conditions: "{{ is_state('input_select.lasko_fan_speed', 'medium') }}"
                  sequence:
                    - repeat:
                        count: 3
                        sequence:
                              cluster_type: in
                              endpoint_id: 1
                              command: 2
                              params:
                              cluster_id: 57348
                          mode: single
                          - delay: "00:00:03"
                - conditions: "{{ is_state('input_select.lasko_fan_speed', 'high') }}"
                  sequence:
                    - repeat:
                        count: 2
                        sequence:
                              cluster_type: in
                              endpoint_id: 1
                              command: 2
                              params:
                              cluster_id: 57348
                          mode: single
                          - delay: "00:00:03"
                - conditions: "{{ is_state('input_select.lasko_fan_speed', 'highest') }}"
                  sequence:
                        cluster_type: in
                        endpoint_id: 1
                        command: 2
                        params:
                        cluster_id: 57348
                    mode: single
                    - delay: "00:00:03"
            - delay: "00:00:05"
            - service: input_select.select_option
                entity_id: input_select.lasko_fan_speed
                option: "lowest"
        - conditions: "{{ percentage == 40 }}"
          sequence:
            - choose:
                - conditions: "{{ is_state('input_select.lasko_fan_speed', 'lowest') }}"
                  sequence:
                        cluster_type: in
                        endpoint_id: 1
                        command: 2
                        params:
                        cluster_id: 57348
                    mode: single
                    - delay: "00:00:03"
                  sequence:
                    - repeat:
                        count: 4
                        sequence:
                              cluster_type: in
                              endpoint_id: 1
                              command: 2
                              params:
                              cluster_id: 57348
                          mode: single
                          - delay: "00:00:03"
                  sequence:
                    - repeat:
                        count: 3
                        sequence:
                              cluster_type: in
                              endpoint_id: 1
                              command: 2
                              params:
                              cluster_id: 57348
                          mode: single
                          - delay: "00:00:03"
                  sequence:
                    - repeat:
                        count: 2
                        sequence:
                              cluster_type: in
                              endpoint_id: 1
                              command: 2
                              params:
                              cluster_id: 57348
                          mode: single
                          - delay: "00:00:03"
            - delay: "00:00:05"
                option: "low"
        - conditions: "{{ percentage == 60 }}"
          sequence:
            - choose:
                  sequence:
                    - repeat:
                        count: 2
                        sequence:
                              cluster_type: in
                              endpoint_id: 1
                              command: 2
                              params:
                              cluster_id: 57348
                          mode: single
                          - delay: "00:00:03"
                  sequence:
                        cluster_type: in
                        endpoint_id: 1
                        command: 2
                        params:
                        cluster_id: 57348
                    mode: single
                    - delay: "00:00:03"
                  sequence:
                    - repeat:
                        count: 4
                        sequence:
                              cluster_type: in
                              endpoint_id: 1
                              command: 2
                              params:
                              cluster_id: 57348
                          mode: single
                          - delay: "00:00:03"
                  sequence:
                    - repeat:
                        count: 3
                        sequence:
                              cluster_type: in
                              endpoint_id: 1
                              command: 2
                              params:
                              cluster_id: 57348
                          mode: single
                          - delay: "00:00:03"
            - delay: "00:00:05"
                option: "medium"
        - conditions: "{{ percentage == 80 }}"
          sequence:
            - choose:
                  sequence:
                    - repeat:
                        count: 3
                        sequence:
                              cluster_type: in
                              endpoint_id: 1
                              command: 2
                              params:
                              cluster_id: 57348
                          mode: single
                          - delay: "00:00:03"
                  sequence:
                    - repeat:
                        count: 2
                        sequence:
                              cluster_type: in
                              endpoint_id: 1
                              command: 2
                              params:
                              cluster_id: 57348
                          mode: single
                          - delay: "00:00:03"
                  sequence:
                        cluster_type: in
                        endpoint_id: 1
                        command: 2
                        params:
                    mode: single
                    - delay: "00:00:03"
                  sequence:
                    - repeat:
                        count: 4
                        sequence:
                              cluster_type: in
                              endpoint_id: 1
                              command: 2
                              params:
                              cluster_id: 57348
                          mode: single
                          - delay: "00:00:03"
            - delay: "00:00:05"
                option: "high"
        - conditions: "{{ percentage == 100 }}"
          sequence:
            - choose:
                  sequence:
                    - repeat:
                        count: 4
                        sequence:
                              cluster_type: in
                              endpoint_id: 1
                              command: 2
                              params:
                              cluster_id: 57348
                          mode: single
                          - delay: "00:00:03"
                  sequence:
                    - repeat:
                        count: 3
                        sequence:
                              cluster_type: in
                              endpoint_id: 1
                              command: 2
                              params:
                              cluster_id: 57348
                          mode: single
                          - delay: "00:00:03"
                  sequence:
                    - repeat:
                        count: 2
                        sequence:
                              cluster_type: in
                              endpoint_id: 1
                              command: 2
                              params:
                              cluster_id: 57348
                          mode: single
                          - delay: "00:00:03"
                  sequence:
                        cluster_type: in
                        endpoint_id: 1
                        command: 2
                        params:
                        cluster_id: 57348
                    mode: single
                    - delay: "00:00:03"
            - delay: "00:00:05"
                option: "highest"
Is this a viable solution, or is there perhaps something I am missing?
Thanks in advance!
I’m assuming there is no way HA knows how long the delay is ?
If I understand the problem correctly, the IR blaster sends a command pretty instantly, but the fan itself takes a few seconds to change its setting, and if you send another command too quickly it would get ignored ?
If this is the case, i think your delay tactic might be the only way, unless…
You could put a power monitoring plug on the fan, and assuming the power level changes enough, depending on the fan setting, you could use this to know the fan speed has changed.
Also… see this thread
With RF there is often no way of making that confirmation.
You can either do a so long delay that it should have been sent successfully, but it would still be a guess, or you would need to invent a sensor to detect it, which Rofo has a good suggestion on.
Hmm, I see.
From what I’m able to tell, given the IR blaster has to be woken up for each press of a button, even though the response is pretty much instant from the Lovelace interface, the fan always reacts to the command at least three seconds too late, which leads me to think that the command isn’t necessarily ignored, but perhaps it rather gets a timeout due to the blaster still handling the previous command.
I assume that if I were to make the blaster behave as if several consecutive presses of the button in Lovelace were just a single (but really long) IR sequence, the problem could get solved, though I’m not sure how feasible this approach would be at the moment.
Is there perhaps a way to handle this with a helper function?
P.D. Sorry for the late reply, it’s been a couple of hectic months and I’m just getting back into domotics.
iR signals are not instant and there are often no way of telling that the end of the signal have been reached. This combined with the shared medium RF is means a transmitter have to wait for the other devices to stop their broadcast and then wait a it longer before it can broadcast.
HA often knows nothing a out broadcast lengths and wait periods, so without delay it just asks the device to broadcast everything and the broadcast device then either only broadcast the first signal or broadcast a bit, then get the command for the next one and broadcast a bitd get the command for the next one and so on.
