Well, it’s December and that means for many people that Christmas trees are going up and getting decorated. Lots of those trees have trains that run around them. And some of those trains are Lionel LionChief trains.
I got to thinking this year about the LionChief BLE and set out to see if I could control the engine from Home Assistant. Turns out, with a little bluetooth sniffing, an ESP32, and Property404’s previous work decoding Lionel’s bluetooth data here, you can create an ESPHome BLE Client for your LionChief engine.
This was a quick and dirty little project – very much a ‘just get it good enough to use’ implementation – and I know there are better ways to implement the controls. I also didn’t implement all of the features.
I believe the service_uuid
varies based on the model you have. I have the Pennsylvania Flyer and the ID is e20a39f4-73f5-4bc4-a12f-17d1ad07a961
. But this is visible when you first set up the ble_client
component and enable VERBOSE
logging level.
The characteristic_uuid
is 08590f7e-db05-467e-8757-72f6faeb13d4
Here is my ESPHome yaml:
esphome:
friendly_name: TrainBLE
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: redacted
ota:
- platform: esphome
password: redacted
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Trainble Fallback Hotspot"
password: redacted
captive_portal:
esp32_ble_tracker:
ble_client:
- mac_address: XX:XX:XX:XX:XX:XX
name: Christmas Train Status
auto_connect: true
on_connect:
then:
- lambda: |-
id(ble_connected) = true;
ESP_LOGD("ble_client_lambda", "Connected to BLE device");
on_disconnect:
then:
- lambda: |-
id(ble_connected) = false;
ESP_LOGD("ble_client_lambda", "Disconnected from BLE device");
globals:
- id: ble_connected
type: bool
restore_value: no
initial_value: 'false'
binary_sensor:
lambda: |-
return id(ble_connected);
device_class: connectivity
button:
on_press:
then:
- ble_client.ble_write:
characteristic_uuid: 08590f7e-db05-467e-8757-72f6faeb13d4
service_uuid: e20a39f4-73f5-4bc4-a12f-17d1ad07a961
value: [0x00, 0x45, 0x00]
on_press:
then:
value: [0x00, 0x45, 0x02]
on_press:
then:
value: [0x00, 0x45, 0x07]
on_press:
then:
value: [0x00, 0x45, 0x10]
on_press:
then:
value: [0x00, 0x46, 0x01]
on_press:
then:
value: [0x00, 0x46, 0x02]
on_press:
then:
value: [0x00, 0x4d, 0x00, 0x00]
name: Announcement Ready to Roll
on_press:
then:
value: [0x00, 0x4d, 0x01, 0x00]
name: Announcement Hey There
on_press:
then:
value: [0x00, 0x4d, 0x02, 0x00]
on_press:
then:
value: [0x00, 0x4d, 0x03, 0x00]
name: Announcement Water and Fire
on_press:
then:
value: [0x00, 0x4d, 0x04, 0x00]
name: Announcement Fastest Freight
on_press:
then:
value: [0x00, 0x4d, 0x05, 0x00]
name: Announcement Pennsylvania Flyer
on_press:
then:
value: [0x00, 0x4d, 0x06, 0x00]
on_press:
then:
value: [0x00, 0x4b, 0x00, 0x00]
switch:
optimistic: True
turn_on_action:
then:
value: [0x00, 0x47, 0x01]
turn_off_action:
then:
value: [0x00, 0x47, 0x00]
optimistic: True
turn_on_action:
then:
value: [0x00, 0x48, 0x01]
turn_off_action:
then:
value: [0x00, 0x48, 0x00]
optimistic: True
turn_on_action:
then:
value: [0x00, 0x51, 0x01]
turn_off_action:
then:
value: [0x00, 0x51, 0x00]
#All Commands
#Horn start: 48 01
#Horn stop : 48 00
#Bell start: 47 01
#Bell stop : 47 00
#Speech : 4d XX 00 (01 to 06)
#Set speed : 45 <00-1f> (hex from 00 to 31) (only implemented slow/med/fast)
#Forward : 46 01
#Reverse : 46 02
#Disconnect: 4b 0 0
#Set master volume: 4b <00-07> (not implemented in current iteration)
#Set steam chuff volume: 4c <00-07> (not implemented in current iteration)
#Set horn volume/pitch: 44 01 <00-0f> <fe-02> (not implemented in current iteration)
#Set bell volume/pitch: 44 02 <00-0f> <fe-02> (not implemented in current iteration)
#Set speech volume/pitch: 44 03 <00-0f> <fe-02> (not implemented in current iteration)
#Set engine volume/pitch: 44 04 <00-0f> <fe-02> (not implemented in current iteration)
#Set lights off: 51 00
When you add this to Home Assistant, this creates a device full of buttons and switches to control the train. There are obviously more elegant ways to implement this, but again, I just wanted to see if it was possible and get it done (relatively) quickly.
Then I set up a dashboard just for the train controls.
And now I can control the train from Home Assistant.
