The entity quickbar is great when programming custom code as you can quickly find the entity in question. The issue is that the only way to actually copy the entity is select it, hit the cog, then select the id and copy paste it. If the copy to clipboard was available at the top filter result (or at least some method to copy the id), ti would save a lot of time programming the cards.
Don’t forget to vote for your own feature request.
