Hi there,
can anyone point me to the correct syntax of how to add CSS to a div with style=“display:none” – and only if it has that style? Would like to use card_mod to remove paddings from those invisible divs, but so far I keep failing.
I think there is a note on card_mods GitHub page that says it only works with ha-card using cards
Thank you, I just realized this, too. rtfm
– having said that… injecting CSS to HA seems to be not an easy task in general. Do you have any recommendations? I tried to set up CSS files as resources for dashboards, but the CSS i put there doesn’t seam to have any effects on the UI.
No idea, sorry.
But maybe there are other cards to use to avoid the problem.
Try posting your YAML code for the cards.
