Available Commands:
check Validates your Home Assistant Core configuration
info Provides information about Home Assistant Core
logs View the log output of Home Assistant Core
options Allow to set options on Home Assistant Core instance
rebuild Rebuild the Home Assistant Core instance
restart Restarts the Home Assistant Core
start Manually start Home Assistant Core
stats Provides system usage stats of Home Assistant Core
stop Manually stop Home Assistant Core
update Updates the Home Assistant Core
