Hi all,
Hopefully a quick one - I’m fairly noob-like when it comes to templates, however I’m finding myself creating lots of identical interfaces in my HA install - for example converting wifi strength entity values into the various strength indicator icons.
I know I can do this with templates, however is there a smarter way I can do this? I’ve seen how you can manually do it for each entity, eg:
sensors:
icono_nivel_senal_wifi_despacho:
friendly_name: Nivel Señal Wifi Despacho
unit_of_measurement: 'dBm'
value_template: '{{ states("sensor.nivel_senal_wifi_despacho") }}'
icon_template: >-
{% set rssi_level = states("sensor.nivel_senal_wifi_despacho") | int %}
{% if -1 > rssi_level >= -50 %}
mdi:wifi-strength-4
{% elif -51 >= rssi_level > -61 %}
mdi:wifi-strength-3
{% elif -62 >= rssi_level > -72 %}
mdi:wifi-strength-2
{% elif -73 >= rssi_level > -83 %}
mdi:wifi-strength-1
{% elif -84 >= rssi_level > -94 %}
mdi:wifi-strength-outline
{% else %}
mdi:wifi-strength-off-outline
{% endif %}
However, this becomes far too much overhead to be useful.
In short, I’m thinking about something like css classes that I can just call to style things - I’m sure it’s possible, I just don’t know what it’s called!
