If I set permanent names using udev rules for the zwave stick and change the path in config, will everything need to be set up from scratch or will python openzwave simply look at the new path?
Should work from the new path, the configuration is stored on the z-stick itself
It’s not the z stick from Aeon but a £6 unbranded everspring. But as long as hass is happy that’s all I need to know thanks! (can move over the rfxcom too and sell the Vera!)
