I’ve been studying programming as a hobby and have been studying the custom cards and components shared on this forum. Funny enough, those were the best resources to learn and develop my own components and cards! Here is one of a few cards I created.
Quote of the Day Card
Download from Github and follow the instructions on the readme.md
That’s odd, can you tell me more about your Home Assistant version and web browser you’re using? Does your Feed Parser sensor show the author and quotes correctly?
Did you also save the bg.jpg file and place in the \config\www directory?
Thank you. Home assistant 0.82.1 in docker with chrome browser. Feed parser is correct.
only difference is that you reccomend putting the card and jpg in /config/www. I have a custom lovelace folder. So all goes to /config/www/custom_lovelace.
I did modify the respective path for the jpg in your card.
Do you use many custom Lovelace cards? Maybe the CSS in my card is conflicting with others. I will try and rename some things to be more specific so they don’t conflict with other card’s CSS.
I’ve updated my card to fix the display of lengthy quotes and added the ability to display more than one quote, though it’s random and I can’t control the refresh time. If someone has a suggestion to improve this, let me know
can someone help please, followed all the instructions and installed feeder and card from HACS, added the relevant lines to config and ui-lovelace, but nothing showing up on page ? and I have noticed the following error in has;
https://m5vy0q1qa99jivkkf41rlxuukcgns11m.ui.nabu.casa/community_plugin/quote-of-the-day-card/quote-of-the-day-card.js:174:30 Uncaught TypeError: Cannot read property 'length' of undefined
This card us only working with Feedparser v0.5 or earlier. Later versions of Feedparser store the data as objects instead if dictionary format, and the card can’t read it. I’ll update the card eventually, once I figure out how to view Feedparser objects…
I’ve followed - I think - the instruction - but the result I’m getting is following -> screen.
What I’m doing wrong?
The only change - there was no file ‘bg.jpg’, so I’ve downloaded other and renamed it…
In the ‘raw config editor’ I have:
So I have it working fine. I have added my own RSS feed, and that works fine. I am trying to change the background image, and no matter what I do it, it will not change. I have edited the js file. and changed it to images/background.jpg and it still comes back with the same image. I have tried it on different dashboards, cleared cache, and rebooted the site a few time.
Can you share the exact configuration you’re using? If the image is stored on /config/www/images/background.jpg, then then configuration should look like this:
