I thought I’d post this here in case somebody else runs into this.
In order to use my imod with the USB Hub from a distance, I need to add it as a device in the QS Mobile web application. Once I did that, the QS binary sensor stopped responding when I open and closed channels. When I removed the imod from the QS Mobile web application and restarted HA, HA registered the channels as being open or closed and all worked 100%.
I added the device again, and the QS binary sensor stopped responding. I tested via the web interface (http://localhost:2020/&listen) and it responded when I open and closed channels.
I put the logs on debug and could not find anything out of the ordinary except that no dispatch events were logged when I open and closed channels.
I added a transmitter button to the QS Mobile web app and that worked 100% so for some reason when the imod was added, well, the sensor didn’t react.
@kellerza any ideas? I can provide logs if required.
At the moment I only dispatch these “sensor” messages for non-devices only – should probably dispatch them for the specific sensor ID’s if you need to add them to QSUSB.
Hi, can look into a fix/update for binary sensors.
Regarding the WARNING, the device you added to QSUSB cannot be decoded into on/off. My suggestion would be that it is changed in pyqwikswitch to a DEBUG with this new usecase
I made some changes to the pyqwikswitch library to change the logging of this specific line to DEBUG and accommodate the decoding of PIR and temperature / humidity sensors. Once kellerza accepts my pull request, I’ll attempt to bring in the changes to the HA Qwikswitch component.
I found it a huge accomplishment to do the pyqwikswitch changtes, looking forward to trying my hand at the HA side.
