R503 - Use MCP23Sxx input as sensing pin
Hello all,
has anyone tried to use a MSP23Sxx pin as sensing pin for the R503 Fingerprint reader?
Is this possible? I do not get a working configuration.
Please don’t bother to post your (not working) configuration and logs as it might helps us to help you :see_no_evil:
For sure sorry.
Below the configuration I’ve tried. I’ve never loaded it to the board because esphome showed me the failure message:
Cannot resolve pin name 'mcp23s17_pin9' for board d1_mini.
Maybe I already found a way. I will check this soon.
esphome:
esp8266:
  board: d1_mini
logger:
  baud_rate: 0
api:
ota:
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "xxxxx"
    password: "xxxxx"
captive_portal:
uart:
  rx_pin: GPIO5
  tx_pin: GPIO4
  baud_rate: 57600
spi:
  clk_pin: GPIO14
  mosi_pin: GPIO13
  miso_pin: GPIO12
mcp23s17:
  - id: 'mcp23s17_hub'
    cs_pin: GPIO16
    deviceaddress: 0
fingerprint_grow:
  sensing_pin: mcp23s17_pin9
  uart_id: uart_r503
  on_finger_scan_matched:
    - homeassistant.event:
        event: esphome.test_node_finger_scan_matched
          finger_id: !lambda 'return finger_id;'
          confidence: !lambda 'return confidence;'
  on_finger_scan_unmatched:
        event: esphome.test_node_finger_scan_unmatched
  on_enrollment_scan:
        event: esphome.test_node_enrollment_scan
          scan_num: !lambda 'return scan_num;'
  on_enrollment_done:
        event: esphome.test_node_enrollment_done
  on_enrollment_failed:
        event: esphome.test_node_enrollment_failed
binary_sensor:
  - platform: gpio
    pin:
      mcp23xxx: mcp23s17_hub
      number: 9
      mode:
        input: true
Solved with the following configuration:
  sensing_pin:
    number: 1
    mode:
      input: true
