The instructions surely help? Radio Browser - Home Assistant
No, it did not. That I already found. And with that I was able to install the integration.
But I did not find anything about how to use it, e.g. how to configure a play_media-service.
Struggled a bit with it too.
Found that radio station are available in the media sections on the sidebar
Yes, that’s true.
But how to use this in automations to start radio-stations triggered by an event?
I don’t have a media section in my sidebar. I searched how to add it, which was to add media_source: to the configuration file but that hasn’t done anything. So I’m as stuck as the OP was.
This is a test I just put together:
alias: Play Radio when motion detected
description: ''
- platform: state
entity_id: binary_sensor.basement_stairs_motion
to: 'on'
condition: []
entity_id: media_player.livingroom_sonos
media_content_id: media-source://radio_browser/4ed4b346-e81b-4570-adbe-8e62ae7a171a
media_content_type: audio/mpeg
metadata:
title: Kaji FM
thumbnail: ''
media_class: music
children_media_class: null
navigateIds:
- media_content_type: app
- media_content_type: music
media_content_id: media-source://radio_browser/country/AO
Where did you find all the media_content
information in the data
section?
I went through the Automations UI and created a new automation, selected the trigger, chose Play Media for the Action, chose my media player from the list, clicked on the big Pick Media + button, chose a random radio station from the media browser radio station list. Once I confirmed the station played as I wanted, I clicked on the hamburger menu at the upper right of the Automation editor and selected Edit in YAML, copied the yaml there and that’s what I pasted in my earlier response.
Let me know if you need screenshots.
Ah, now I got it!
My mistake was to use the run-service-function, where I need to now the content-ID.
But instead I have to use the play-media-action.
Thanks a lot!
Hi, sorry but how did you find the link?
In dev tools/states while playing the station.
I find it easier to do through the website radio-browser.info - go find your radio there, and click on it, in the url you will get the content id , for example:
https://www.radio-browser.info/history/9617a958-0601-11e8-ae97-52543be04c81
Yes, thanks, but at the moment it doesn’t work with browser-mod
Thanks, this worked for me. I needed to use the stationuuid
Play radio via Home Assistant - Rouwette.com
This may help
Easy way to find content id is via an Automation
And play it with a button
been trying for 3 days to get this to work. i keep getting Media player does not support browsing media when i try to create an automation to play a radio station with radio browser
Crystal ball broken.
To get help you need to post your automation and your logs.
From what I read online, I do not think you can use alexa as a media player for this.
If I use another media player, it does work
