Radio Browser - how to use?
You’ll need to set up a media player on the mini that will show up in HA, like an mpd container.
Thanks.
Let’s say I will use VLC as media player in the mini.
Do I need to add the VLC add-on in HA or is that not required, will HA see the VLC player in the network?
Probably better to install the squeezelite addon.
I have been trying to add this station and nothing I do works. Can someone help me or add it for me? Thanks
103.9 dayton’s new country
If it isn’t already in radio browser you’ll have to add it here. radio-browser.info
Not a home assistant issue.
I tried adding it but it wouldnt work.
Ask the people who run radio browser. This is not their sorry channel.
If adding through radio browser page fails, you could try tunein.com route. Make sure you add your radio station to library and refresh Radio tab in MA.
Hi, I have an Onkyo TX-NX616 AV Receiver and wanted to use your code to direct stream streams from Radio Browser. I am a bit confused because I have 2 integrations for this onkyo:
  1. from the “Onkyo” Integrations with following attributes (media_player.tx_nr616):
type: custom:mushroom-template-card
primary: Radio GÖD (with Onkyo Integration)
icon: mdi:radio
entity: media_player.tx_nr616
multiline_secondary: true
tap_action:
  action: call-service
  service: media_player.play_media
    media_content_id: media-source://radio_browser/4f1fb5fa-8a10-4d72-b247-21d831272373
    media_content_type: audio/mpeg
    entity_id: media_player.tx_nr616
fill_container: false
secondary: "{{ states('media_player.tx_nr616') }}"
hold_action:
  action: more-info
and 2) from the “DLNA Digial Media Renderer” integration (media_player.onkyo):
primary: Radio GÖD (with DLNA Intergration)
icon: mdi:radio
entity: media_player.onkyo
tap_action:
    entity_id: media_player.onkyo
secondary: "{{ states('media_player.onkyo') }}"
hold_action:
  action: more-info
In both cases the onkyo does not stream, any idea why?
Must I switch to a certain input, if yes which? I tried already DLNA, NET, Internet Radio…
My tX-NR696 uses the Chromecast item in NET to stream from the radio-browser on HA running on a Pi4 to my Onkyo. make sure you install the google Cast integration on HA if it is not installed already.
