neil-w
November 30, 2022, 10:43am
1
I have created some buttons on a flashed NS Panel to control LED strips and I’m trying to get it to work where only one pattern can be selected at a time. I have created some automations which works but it’s messy and not scalable. The automations look like this:
If button 1 is pressed then turn off buttons 2 and 3
If button 2 is pressed then turn off buttons 1 and 3
If button 3 is pressed then turn off buttons 1 and 2
Is there an easier more scalable way to achieve this?
tom_l
November 30, 2022, 11:58am
2
Use an input select helper.
neil-w
November 30, 2022, 12:42pm
3
But I don’t want a drop down? I have 6 buttons and I want them to be exclusive so when I turn 1 on the previous selected one is turned off. The same way a radio button works in HTML.
neil-w
November 30, 2022, 1:15pm
5
Here are the full details of what I’m trying to achieve. I have an NS Panel which I’m using nspanel-lovelace-ui on. I have a cardGrid which has 3 buttons, each of these buttons currently calls a different preset on WLED.
Here is my app.yaml:
cards:
- type: cardGrid
title: The Bar Lights
key: cardgrid1
entities:
- entity: light.button_1
icon: mdi:led-strip-variant
- entity: light.button_2
- entity: light.button_3
- entity: input_select.tester_radio
light.button_1 references a group which in turn references the following 3 light options (3 because I have 3 separate WLED controllers):
# Button 1
lights:
bar_cp_button10:
friendly_name: "The Bar CP Button 10"
turn_on:
service: select.select_option
entity_id: select.outer_lights_preset
option: G-Fireworks
turn_off:
option: Power Up
lights:
bar_cp_button11:
friendly_name: "The Bar CP Button 11"
turn_on:
entity_id: select.bar_lights_preset
option: G-Fireworks
turn_off:
option: Power Up
lights:
bar_cp_button12:
friendly_name: "The Bar CP Button 12"
turn_on:
entity_id: select.ceiling_matrix_preset
option: G-Fireworks
turn_off:
option: Power Up
Then I have an automation which turns off buttons 2 and 3 when button 1 is selected:
alias: Light Button 1
description: ""
- platform: state
entity_id:
- light.button_1
to: "on"
condition: []
- service: light.turn_off
data: {}
entity_id: light.button_2
data: {}
entity_id: light.button_3
mode: single
I have to duplicate these automations for each button so 6 buttons equals 6 automations.
Hope that makes sense.
123
(Taras)
November 30, 2022, 1:37pm
6
This automation turns off all lights except the one that just turned on.
alias: Light Button
description: ""
- platform: state
entity_id:
- light.button_1
- light.button_2
- light.button_3
- light.button_4
- light.button_5
- light.button_6
to: "on"
condition: []
- variables:
lights:
- light.button_1
- light.button_2
- light.button_3
- light.button_4
- light.button_5
- light.button_6
data: {}
entity_id: "{{ lights | reject('eq', trigger.entity_id) | list }}"
mode: single
neil-w
November 30, 2022, 1:52pm
7
That works perfectly! Thank you.
(Taras)
November 30, 2022, 2:01pm
8
This service call should work a bit more efficiently. Instead of turning off all lights except the one that just turned on, it only turns off the lights that are currently on
but should now be off
data: {}
entity_id: >
{{ expand(lights) | selectattr('state', 'eq', 'on')
| map(attribute='entity_id')
thermiek
(thermiek)
April 15, 2025, 7:18pm
9
i made a template with 2 inputs , and a single off protection
alias: Consolidated Radio Button Control
description: Maintains single active state between two input_booleans
triggers:
- entity_id:
- input_boolean.een
- input_boolean.twee
- "on"
- "off"
to:
- "on"
- "off"
trigger: state
conditions: []
actions:
- choose:
- conditions:
- condition: template
value_template: "{{ trigger.to_state.state == 'on' }}"
sequence:
- target:
entity_id: |
['input_boolean.een', 'input_boolean.twee']
| list
action: input_boolean.turn_off
- conditions:
value_template: "{{ trigger.to_state.state == 'off' }}"
value_template: |
| select('is_state', 'off')
| list
| count == 2
sequence:
- target:
entity_id: "{{ trigger.entity_id }}"
action: input_boolean.turn_on
mode: queued
