I don’t see a place where I can fix this.
This is my setup, the only place I see them is in the UI, but clicking the gear shows the above issue.
Thermostats
climate:
- platform: radiotherm
host:
- 192.168.1.16 = climate.thermostat-75-AD-F0
- 192.168.1.17 = climate.livingroom
Home Assistant Core 2022.5.5
Home Assistant Supervisor 2022.05.3
Home Assistant OS 8.1
Kernel version 5.15.41
Agent version 1.2.1
Thanks for any help,
Rob
tom_l
2
Which thermostat integration are you using?
This one?
If so, it does not support a unique id. A lot of integrations don’t. You can make a feature request for it here:
OK thanks, yes this is the one. I will make a request. Are there instruction on how this would be done? Could I download the source and add it myself?
Thanks,
Rob
tom_l
4
Well yes you could but it would be better if you submitted a PR to change it for everyone.
