Radiotherm temperature reading bug
Hi all, I’ve been playing with Radiotherm CT50 for few weeks now, it is working relatively well, but sometimes it reads current or target temperature as -18.3 C, which is getting quite annoying. I suspect something is wrong with polling, maybe its being polled too often or just random wifi dropouts or something, so that HA cannot get a value for temperature and assumes in is -1 F == -18.3 C.
I looked at the logs and saw error “Human readable value not known for raw value -1”, so I tried fixing this file radiotherm/radiotherm/fields.py at master · mhrivnak/radiotherm · GitHub not to raise that KeyError. It might have helped for a while (or maybe I just got lucky for that time), but then I saw those -18.3 again.
I tried to increase scan interval like this, but it did not help.
climate:
  - platform: radiotherm
    hold_temp: true
    scan_interval: 60
    host:
      - 192.168.1.6
The only relevant thing I get from log after fixing the above things is the following.
Any suggestions on how to proceed with debugging this? I don’t have much experience with linux networking, but I thought if there is a way to get some kind of trace/log of network traffic to thermostat, it should probably be helpful.
Check your fields.py file again. If you recently updated Home Assistant, it is possible your changes got clobbered.
I have a CT50 as well, and can confirm that the radiotherm package reports a value of ‘-1’ anytime it gets a result it doesn’t understand from the thermostat. (I believe this includes a timeout). I’m not sure if it’s the thermostat or the code, but this happens on average a dozen or more times a day here. If your values are all being converted from F to C, that would explain the ‘-18.3’ you keep seeing.
The scan interval doesn’t seem to have any effect.
As a stop gap, you could have your template check for and discard that specific value, although a better fix would be for the radiotherm package to get updated. The package being used by Home Assistant seems abandoned by it’s maintainer. There are PRs over a year old waiting to be pulled in. Maybe switching to a newer fork, or forking a branch just for HASS would be appropriate?
