RadonEye RD200
As of today I’m using a ESP32 to avoid the “beep” I had when using the RadonEye with the SmartPhone app. By connecting the device via Bluetooth the beep isn’t there anymore and I get nice statistics within HomeAssistant how my Radon exposure is. The ESP32 acts as a Bluetooth proxy via WLAN. This is needed, because my home assistant server is too far away from the RadonEye device, they don’t match via Bluetooth because there are too much walls inbetween.
My question to the community is:
Is there a possibility, to get long-time graphs for the Radon values? I suppose, “Grafana” would be a nice solution for this. But how can I integrate Grafana so that the captures of RadonEye can be used?
esphome:
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "this_was_automatically_generated_by_HomeAssistant_ESPHome_AddOn"
ota:
  password: "12312312371647814387152471812"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Esp2 Fallback Hotspot"
    password: "4dBynjKSBA8H"
captive_portal:
esp32_ble_tracker:
ble_client:
 - mac_address: eb:50:32:xx:xx:xx
  - platform: radon_eye_rd200
    ble_client_id: radon_eye_ble_id
    update_interval: 5min
    radon:
      accuracy_decimals: 2
    radon_long_term:
      name: "Radon Long Term"
I have a new RD200 and I wanted to connect it to homeassistant but I can’t. Could you help me? Could you give me some advice on how you have it set up?
thank you
I have bought a ESP32 device and installed the ESPhome software (https://esphome.io/) on it. This ESP32 acts as a gateway between WiFi and Bluetooth, because my RD200 has no WiFi.
Then i completed the configuration with the above commands to include the RD200 functionality on the ESPhome device and installed this software on the ESP32 device (you’re using the ESPhome Builder within Homeassistant for this). The most tricky part is to get notice of the Bluetooth MAC-address xx:xx:xx:xx:xx:xx of your RD200 device to be able to configure it into the code. You’ll probably have to scan bluetooth traffic. So, when this is settled, ESPhome sends its collected values (via mqtt) to the Homeassistant.
