I am trying to make a digital Rain drop sensor on D8 of a Wemos D1. This should be a digital in/out.
I attached a Rain drop sensor , which includes a LM393. I created the following code in esphome:
binary_sensor:
- platform: gpio
pin:
number: D8
device_class: moisture
But it is not working. I can turn the sensor on with the potentionmeter, led is on, but no log on the esphome output log and no change in HA.
Who has an idea?
tom_l
July 30, 2020, 4:40pm
2
Sounds like a wiring fault. How did you power and connect the sensor to the ESP?
Just simple. Vcc to 3,3v, ground to ground, and d0 of the lm393 to d8 of the wemos.
Troon
(Troon)
July 30, 2020, 5:11pm
4
See here : perhaps rewire and recode for one of the pins labelled OK for input.
d8 is “ pulled to GND” according to link. Should I make a change in esphome? To e.g. INPUT_PULLDOWN?
tom_l
July 30, 2020, 5:32pm
6
No you should wire the sensor to
Strange; testing on D5 is working now, i tested D7 and that is working not either. D5 is working so fine to me.
Llammy
March 27, 2022, 1:11pm
8
Would you mind helping me?
my code is as follows
esphome:
esp8266:
board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
password: !secret otapassword
wifi:
ssid: !secret wifi_ssid
fast_connect: true
ap:
ssid: "Rain-Sensor Fallback Hotspot"
password: !secret rain_sensor_password
captive_portal:
switch:
- platform: gpio
pin: D0
name: "Rain sensor power"
- platform: adc
pin: A0
- platform: resistance
sensor: source_sensor
configuration: DOWNSTREAM
resistor: 5.1kOhm
reference_voltage: 3.3V
internal: true
icon: "mdi:omega"
on_value:
then:
- if:
condition:
lambda: |-
return (
id(real_resistance_sensor).state > 100
then:
- sensor.template.publish:
state: !lambda 'return ON;'
But i get a compile error 'Unable to find action with the name ‘sensor.template.publish’ ’
