Surely someone has the code and device for a cheap aliexpress flipper for rain? I have not found it with Google.
Thanks,
Grey
Thanks,
Grey
Just use a pulse counter - typically the buckets tip once per 0.1mm of rain. Add a time sensor to do an on_time:
reset of the sensor at the end of the day.
- platform: pulse_counter
pin: 12
unit_of_measurement: 'mm/min'
name: 'Rain Rate per minute'
filters:
- multiply: 0.10 # pulses x 0.1mm for default 60s
total:
unit_of_measurement: 'mm'
filters:
- multiply: 0.1 # 10 pulses per mm
I think I have the math right. For other bucket sizes just multiply by the mm per bucket.
Are you married to an ESPhome solution? I was looking for a rain gauge too and found this, using a $10 gauge and a open/close sensor. Works well!
thanks, I will give it a go !
@zoogara Can you share the purchase link to the gauging device you are using with this ESPHome implementation. Which chip or board are you using for ESPHome?
Never mind! I got it from the link shared by @nappyjim to this post.
Stumbled on your thread here as Im also curious about adding my own rain gauge to my system. The $9 Aliexpress gauge seems like a good starting point but I was curious if someone has made a 3D printed version and sure enough, several people have. Here is one ESP8266 Rain Gauge by gineer - Thingiverse and here is another that is a copy of the Aliexpress one Rain Gauge by samshadnc - Thingiverse
