Strange. It works for me and I have no subscription. That said, it geolocates to my IP address.
Search config-template
config-template does not find anything.
Is there something wrong with mu HACS installation?
âconfigâ finds 7 items.
WellâŚmaybe.
I couldnât get your card to work. After some research, the custom:hui-iframe-card no longer exists, you have to replace it with custom:hui-element and define the card type iFrame.
type: custom:config-template-card
entities:
- sensor.iphone_de_michel_geocoded_location
card:
type: custom:hui-element
card_type: iframe
title: null
url: >-
${'https://embed.windy.com/embed2.html?lat='+states['sensor.iphone_de_michel_geocoded_location'].attributes.Location[0]+'&lon='+states['sensor.iphone_de_michel_geocoded_location'].attributes.Location[1]+'&detailLat='+states['sensor.iphone_de_michel_geocoded_location'].attributes.Location[0]+'&detailLon='+states['sensor.iphone_de_michel_geocoded_location'].attributes.Location[1]+'&width=650&height=450&zoom=6&level=surface&overlay=rain&product=ecmwf&menu=&message=true&marker=true&calendar=now&pressure=true&type=map&location=coordinates&detail=&metricWind=mph&metricTemp=%C2%B0F&radarRange=-1'}
aspect_ratio: 135%
With thanks to @afxefx for the inspiration, I took the following as a challenge to myself.
Edit: Updated YAML to display radar and lightning. The animation covers a 6-hr period.
Edit 2: I was successful in getting it to work with the Manual UI card. YAML has been updated with appropriate indenting.
Edit 3: Removed unnecessary YAML content.
Make sure the config-template-card
is properly configured. When you download it with HACS, the resource file will be in directory /config/www/community/config-template-card
, and the file should be referenced to look for the resource file at URL: /hacsfiles/config-template-card/config-template-card.js
. If the resource for the config-template-card canât be found, itâs likely the resource file isnât properly configured.
If you have problems, look here for tips: https://github.com/thomasloven/hass-config/wiki/Lovelace-Plugins
The rest should be easy if you have an iPhone (For an Andoroid, look at Rain radar integrations - #17 by afxefx for YAML guidance). This following is what works for me (I used the default iPhone entity and attributes), but it can be tweaked if youâre willing to experiment.
entities:
- states['device_tracker.iphone']
card:
type: iframe
title: Windy Radar
url: >-
${'https://embed.windy.com/embed2.html?lat='+states['device_tracker.iphone'].attributes.latitude+'&lon='+states['device_tracker.iphone'].attributes.longitude+'&zoom=5&level=surface&overlay=radar&menu=&message=true&marker=&calendar=&pressure=&type=map&location=coordinates&detail=&detailLat='+states['device_tracker.iphone'].attributes.latitude+'&detailLon='+states['device_tracker.iphone'].attributes.longitude+'&metricWind=mph&metricTemp=%C2%B0F&radarRange=-6'}
aspect_ratio: 135%
The aspect_ratio can be changed per your preference.
Thatâs great! Q: How to remove isolines from the map? Canât figure it out in the code.
NB: Found it. pressure=false
